P0171 - System Too Lean (Bank 1)
nasdamus
Looking for some thoughts. 2003 V6. Keep getting a P0171 code. I pulled the MAF and cleaned it, same with the TB. Came back on after 10 miles. I checked all the vacuum hoses, all seems fine. I replaced the MAF with a known working extra i had, came back after 15 miles. Replaced the air filter (had to anyways), ran some Techron Fuel System Cleaner through a full tank of Shell gasoline. Took a little while to come back on but eventually did (maybe 45 miles).
5,000 miles ago I did replace all spark plugs as well as the PCV valve.
2.5 years ago (20,000 miles ago) i replaced the B1S1 o2 sensor (was getting a P2238 code) with a Denso 234-9047.
Any thoughts on what i should try next? Been searching around and checked most suggestions. I'm currently getting a real rough idle at stop, not stalling out but close.
Need more information, but I'm leaning towards a fuel system problem. Are you able to get fuel trim (both short and long term) info? Preferably for both idle and 2500RPM conditions.
I have the same 4Runner, and I'm currently getting P0171 & P0174....checked Vacuum hoses for leaks...all good. All O2 sensor were replaced 3000 miles ago, MAF & TB are fine....The vehicle intermediately bogged on upon acceleration.....Saw A video on this saying it could possibly be a clogged cat, putting excessive exhaust pressure on the engine. So I pulled my cats and noticed one was clogged, I cleaned it and now it got worse. The vehicle just has no pick up when pressing the gas. (Yes I replaced the Fuel Pump a few months ago) I'm going to drill out my cat to see if it remedy's the situation...I'll let you know.
i'm having the same issues along with a misfire on cylinders 2-6, also getting "system too lean", and engine sounds like it's running on half the cylinders and bucks when starting out from a stop. i've replaced:
1. plugs
2. wires
3. coil packs and boots
4. pcv valve and gasket
5. mass air flow sensor
6. air filter (k&n cold air intake already installed, engine ran flawless on this for 10 years now)
7. put injector cleaner via fuel tank 4 times now each on a full tank of reliable gas.
8. o2 sensors (both done 10 k miles ago no issues yet there or codes)
what should i do next? i'm thinking its in the throttle body sensor and the idle air control unit. am i right or is it the injectors at this point? PLEASE HELP I NEED TO GET THIS FIXED ASAP
1. plugs
2. wires
Did you ever solve this? I'm getting the fault and misfire on cylinder 1. I don't want to start throwing parts at it if I can help it.
Was getting the code off and on for a couple months. Tracked it down to a crack in the header manifold. Replaced both sides with some JBA shorties and haven't had a problem since.
How did you find the leak in the manifold? Was it pretty obvious?
Could you provide a link for the headers you bought?
On sale at URD, probably cheaper elsewhere or if you wait until black friday. Different coating options available.
https://www.urdusa.com/jba-headers-2035sjs-tacoma-05-11-v6-fj-cruiser-07-09-03-09-4runner-v6-tundra-05-06-v6-silver-ceramic/
I could hear a ticking/exhaust sound that wasn't normal inside the bay and eventually the crack grew large enough I could see it just from looking. It was a shitty weld on an aftermarket header for me but the codes are a pretty good indicator of a leak. You can use a cheap stethoscope without the end on it to listen to areas of the manifold and identify the leak. Or just bring it in to a shop for a quote and they'll find it for you.
to summarize, the causes can be:
1. cracked header manifold
2. defect O2 sensor
Anything I miss?
I have the same symptoms and guess its the manifold, but before starting works I collect all the possible causes!
2. defect O2 sensor
Anything I miss?
I don't want to muddy the waters, but I'll add that I got this code after having a misfire on cylinder 1. It was misfiring bad enough to cause the too lean code. If you don't have a misfire I think your list is correct.
A lean bank on only one side can be down stream sensors, or it could be fouling injectors.
I THINK A CRACK IN THE MANIFOLD of that bank could also throw the CEL. lemme look at my oxygen sensor readings again , last time i checked, they looked fairly normal/within range
See my trims below
Freeze frame report generated by Torque for Android
Vehicle VIN: JTEBU14XXXXXXXXX
Vehicle Manufacturer: Toyota
Vehicle Calibration ID: 33535000
Freeze frame information:
Fuel Status = 0 byte
Engine Load = 15.686 %
Engine Coolant Temperature = 185 °F
Fuel Trim Bank 1 Short Term = -0.781 %
Fuel Trim Bank 1 Long Term = 12.5 %
Fuel Trim Bank 2 Short Term = -1.562 %
Fuel Trim Bank 2 Long Term = 38.281 %
Engine RPM = 613.25 rpm
Speed (OBD) = 10.563 mph
Timing Advance = 18 °
Intake Air Temperature = 111.2 °F
Mass Air Flow Rate = 3.98 g/s
Throttle Position(Manifold) = 16.078 %
Run time since engine start = 126 s
O2 Sensor1 Equivalence Ratio = 1.024
O2 Sensor5 Equivalence Ratio = 1.021
Distance travelled since codes cleared = 1.243 miles
Barometric pressure (from vehicle) = 14.504 psi
Catalyst Temperature (Bank 1,Sensor 1) = 869.72 °F
Catalyst Temperature (Bank 2,Sensor 1) = 869.72 °F
Catalyst Temperature (Bank 1,Sensor 2) = 264.2 °F
Catalyst Temperature (Bank 2,Sensor 2) = 264.2 °F
Voltage (Control Module) = 12.968 V
Engine Load(Absolute) = 16.078 %
Commanded Equivalence Ratio(lambda) = 1.005
Relative Throttle Position = 0 %
Absolute Throttle Position B = 47.451 %
Accelerator PedalPosition D = 16.078 %
Accelerator PedalPosition E = 32.157 %
End of report.
charlesz
