Heck yeah!
Told you it was going to be fine!!!!
Glad it worked out!
Good to hear you have confidence your guys figured it out.
I hope your good luck remains and it doesn't start acting up again...
I am not an expert either. Like someone mentioned above, my guy said seafoam in the gas and revving it every once in a while will keep the deposits down. He did 2 induction cleanings and let me tell you, the car feels brand new! Appears as though it is fixed. Total bill with all the diagnostics, the compression checks, and induction services was under $300.I am NOT an expert so I'd be curious to hear more about this. The carbon in the cylinder bore may or may not be the ultimate cause of your rough running engine, but wouldn't the carbon itself be a symptom of something else? It couldn't be normal for one cylinder to get gunked up and all of the others be OK. I mean what's different about that one cylinder that makes it prone to this sort of thing?
Which cylinder was it?
Should also point out that I do not know how dirty the other cylinders were. It could have been that particular cylinder hit a "threshold" causing valves/rings/etc to stick (????). All I know is, that coming home I might or might not have driven it like I stole it, and it is hella fast and has a ton more power.
It is a BG product that is put through the engine. I have had it done on past vehicles, and it works. It is not seafoam that he put in, although he does recommend it as a gas treatment from time to time. Either way, it seems to have worked for now, and he did not charge new for the labor of putting in and switching out the coils twice. Started up this morning fine. Hopefully it will last me for a few more months. If the problem comes back, three next drive will be to a dealership to trade it in....either on a current year Tacoma or the new Colorado.
It's good to hear you have a plan for when, I mean if, it acts up again.
Damn man....what is up with all those negative waves?! =)
Considering i will trade it in in the next few months negates that bet. I will either be purchasing a current year Tacoma, or a 2016 when it comes out around August. Need a pickup for my general contracting business.I'm just a realist...
From all the reading I've done on this topic (it's a lot because I'm paranoid about it owning an 05 V6), the 1GR-FE head gaskets do not fail often, but when they do, the failure sequence always starts with a cylinder misfire code, usually P0306 or P0304.
Take that for what it's worth... Long term I would be positiong yourself financially to either replace your head gasket or to trade it in on a new vehicle.
How's this... a friendly wager. I'll bet you a $25 gift card (of the winners choosing) your head gasket fails in the next year assuming you continue to keep it as your daily driver. If it doesn't fail, you win, If it fails, I win.
