I would still be willing to bet it is the HG, even with the compression test passing.
Me too, unfortunately. A leakdown test would be more conclusive.
If its a V6 with #6 misfire and mostly happens when it sits for a while then its the head gasket. Seen plenty and done a few, Spark plus i doubt it i've seen these with 260k on stock plugs and it still runs perfect which is crazy for a 30k plug.. Im a Toyota Master tech if it matters.
Testing compression wont matter it will read good, dont bother wasting your time, these engines are pretty much bullet proof besides the odd head gasket issues or the front covers leaking.. I own a V8 so i didnt have to deal with it if it happened:lmao:
Sorry for reviving an old thread, but I have a similar issue....with a twist....
Pretty much same as everyone else... except I have not detected any loss in coolant.... AND...
Wife started it yesterday... CEL comes on - rough idle... but did not stop after a few seconds like if normally does.. (when this occurs - which is not always).
She drives down the road half a mile.. stops (we live in the country), shuts the car off completely..... restarts... CEL is gone, and the engine runs as smooth as can be?
Anyone else had that occur ?
Odie1
i have the same issue with the fine / not fine P0306. I'll get the misfire, turn the car off, turn it back on, and then the misfire is gone. all within 5-10 seconds. Any explanation or remedy for this? I don't understand how a bad headgasket would sometimes be problematic and other times not? thanks for any help!
