P0306 - My Experience
stir_fry_boy
Hi everyone, I wanted to tell everyone about my experience with a P0306 code that came up suddenly yesterday. Everything I read told me I would need an injector, however that wasn't the case.
About 75,000 miles ago, I replaced the spark plug wires with Prestolite brand. They are supposed to be OEM quality, and I was told that Prestolite makes wires for many auto manufacturers. I also replaced the spark plugs with OEM NGK approx. 15,000 miles ago.
I pulled the plug - looked perfect (phew). I then had my wife try to start the car with the plug connected to the wire outside of the cylinder - no spark.
I pulled plug #4, swapped the plugs - no spark in cylinder #6.
I swapped coil packs and the associated wires with cylinders 3&5, still no spark in cylinder #6.
I determined it must be the wire going to cylinder #6.
I live in a small town, so finding NGK or OEM wires is at least 1 hour away, making a round trip about 2.5 hours. So, I went with NAPA Belden wires. I read good things about them. I also bought 3 rubber boots for the coil packs that have never been replaced.
Yep, that fixed the problem. In my limited understanding, usually wires go bad intermittently, however this was sudden. I knew it was not likely to be the plugs - again usually slow degradation of MPG and performance and sometimes intermittent CEL.
A good friend is a Toyota Master Tech, he told me that he has never heard of a wire going suddenly like that.
Just thought I would give my $.02 since everything I read was "replaced injector to fix". Glad I didn't just tear into the truck only to find it was just a spark plug wire.
For the record, NAPA sells the NGK TE66 wires. I'd post a link, but their site is down--just a big Check Engine Light on the page.
Not the NAPAs around me, I called all of them within a 75 mile radius. They are all independtly owned.
Has anyone had experience with the Belden wires?
Put some Belden wires in a Pontiac Grand Am with the 3800 in it once after changing out the moronically made plastic coolant elbow on that engine. Seemed to run well until the daughter of the owner put it into a tree 15,000 miles later.
I found my Denso wires in a mom and pop auto store in Georgia for $10.
Well, here is the link:
NAPA AUTO PARTS
I bet any of those stores could get it by the next day if you gave them the part number NGW 4412. NAPA counter guys ain't too bright.
$33 instead of $29 on Amazon Prime or Rockauto with shipping.
Yeah, since it was a Saturday, they couldn't get them in until Tuesday. Could have ordered them on Amazon and got them here by then. I didn't want to wait and be down a vehicle for 3 days for $20 more, and from what I read, good reviews on the Belden wires.
The Belden wires seem to be very high quality and robust.
I could have driven to Phoenix and got the Denso ones, but would have cost me $40 in gas and 3 hours in drive time.
Gotchya. I just didn't want folks to think they couldn't get them at NAPA if they wanted to. I really like my local NAPA and its owner where I've been buying since the store was built around 1973. I try and get anything I can there, if it's price and quality competitive or just a little more expensive.
His counter guys are still idiots. The long-term smart guys all left for better gigs years ago.
Yeah you can get the NGK ones from NAPA or AZ by special order.
Would anyone remove the Belden wires to put on OEM ones?
Naw, it's not like OEM wires are made of magic pixie dust or something. They may just not last 15 years like the OEM do!
An easy thing you can do in the future is using a multimenter, check the resistance (ohms) from one end of the wire to the other. Any abnormally high readings indicates a problem, the FSM said over 25k I think but I would begin to suspect anything over 10-15k to be honest. Brand new most wires are in the 6-7k ohms in my experience. Easier than switching coil packs around.
