p0333 Help! 10 4Runner Limited
Stewmatic508
:Cry: I have 3 Lights on Check Engine, Traction control and 4lo that flashes constantly. I checked the codes and got a p0333 which is being classified as a knock sensor. A few weeks prior I got these same lights on and was able to reset them and the lights went away. I also noticed I am not able to get into 5th gear. The car seems to make very little attempt to get into 5th gear at all. Anyways I am looking for some advice on this. thanks in advance for any advice.
Did you get anywhere on this? My '10 4runner threw the same code last week. I recently had rodent damage and repaired it (it was the injector harnesses that they feasted on). I haven't found any posts regarding this error code for the 5th gen. Are we just that unlucky, has anyone done this repair or is it the same as the 4th gen repair?
it's knock sensor code. May be the rodents chewed the sensor wiring. Have to take the plenum off to check it unfortunately.
