P0446 troubles
troy_279
So after throwing this code almost weekly (along with 0440 and 0442) with my 02 limited I'm getting tired of resetting the CEL. From the extensive reading that I've done I think I'm at the point of replacing the VSV at the charcoal canister. I've checked all the lines and everything looks good so I guess this is the cheapest part to replace first. My question is has anyone ever used anything other than a genuine toyota part? I have found that my local Canadian Tire (yes, here in Canada) has the part from a company called Dorman. I was just wondering if anyone has tried this part.
Well I decided I would just call my local dealer and order the VSV. For some reason they gave me an item number of 90910-12245 and I thought I needed 90910-12264 and they gave me a price of $100. I didn't order yet, hoping an expert here would chime in.
I had and still have PO446. Took it to a mechanic and did smoke test (nothing). He tested the two valves on top of charcoal canister (98 4R) and both had failed. He replaced both for $300 and I still have the PO446. This was a year ago and I still have the code every now and then. I just turn it off as I still get good gas mileage (~20 mpg). So far my PO446 has cost me $360 USD. It's probably the charcoal canister in my case.
Well I'll pick up the Dorman VSV tomorrow and put it in to see what happens. I got the whole charcoal assembly off tonight so i'm ready to bolt the new one on and re-assemble. I must say what a PITA. It took me over an hour to get the assembly off but on a good note I only broke one bolt! I can't even imagine changing the VSV without taking the whole assembly off the truck.
Well after a day the 0440 and 0446 are back. I guess a new gas cap is in order first and we'll go from there.
I've got this same issue. Just haven't gotten around to taking a look at it yet. Have you noticed a decrease in your gas mileage since you've had this code?
Also, when I go to check the VSV and/or the charcoal canister, do I need to remove the gas tank? Thanks.
That is an excellent thread and I've read it and it seems a hundred more that google has found. After replacing the VSV at the charcoal canister I'm still throwing codes. It is now 0440, 0441 and 0446. I just went with what seemed to be the common fix with the VSV but I guess I'll get out the multimeter tomorrow and test the switches under the hood and go from there.
Well I had a couple minutes today so I got a chance to test all 3 VSV's. All 3 are with specs for ohms according to the service manual but i wasn't able to connect 12V to see if they actually created vacuum. I inspected all line from the front to back and all look good. I guess its time to find a charcoal cannister.
What part of Canada are you from? If you live in a salty area, the condition of your filler pipe might be worth a check. My pipe was a mess, so replacing it was a good idea anyway. I still had the code, but a new gas cap fixed it. Now, the PO had the code and tried a gas cap first. I guess it is possible that his OEM cap was shot and the new one just didn't work, but I think that it was a combination of the pipe going and then the replacement cap sucking. Anyway, I don't have the codes anymore. One of my valves was replaced, but it did squat (or it could have been a third piece to the puzzle. I was reluctant to do the canister because of price.
Solution for P0446
Solve your P0446 easily: 1999 Toyota 4cyl 4runner EVAP Canister fix P0446 - YouTube
Had the P0446 for years. I read forums, chased down vacuum leaks, and tested canister valves - I did conclude it was the canister. But, I got into the habit of clearing the OBD and driving just the "right" amount of miles to pass emissions before the check light returned. Today, emissions test due, and I had tracked down a 4runner at a junkyard to go pull/buy the canister. Thought I would review a vid on replacement 1st and came across this as I was getting ready to leave. Did the spray test and bingo! I had leaks on both front corners! I really love fixing stuff vs. trashing it. JB plastic weld, passed emissions, exhaust literally smells better; and I'm confidant this was the cause of P0446 and a great solution.
Talyn
