Painting center caps
octanejunkie
Elite Member
After 17 years of tire shops mishandling our center caps, mine are almost completely devoid of silver paint
Is it just as easy to pull and clean well then re-shoot with silver wheel paint (after primer) or is there another preferred method?
NB, after I refurb mine I will pull them myself before going to the tire shop coz those guys just don't care about yo center caps.
I got tired of mine looking like crap and them off and sprayed with Rustoleum high heat silver #270201 (because that's what I had on the shelf) and they came out remarkably well. The wheels are dirty but the color is quite close. Paint is cheap also.
I painted my center caps when I painted my wheels a while back. Scuff them up well with either a red scotchbrite pad or sandpaper and then sand smooth; use a good primer (I used a plastics-specific one, but you can use whatever you want), and then on top of it use the closest paint match you can. I just used the same wheel paint I used on my rims and then used two coats of clear; AutoZone sells a brand of paint called VHT that has wheel specific spray paint in a silver color that would match pretty well. It's held up very well after about a year and a half.
The regular Rustoleum silver metallic is tom me an exact match. You can take the caps off by popping them off with a flat head screwdriver. There's a little slit on the caps. (In case you didn't know). I painted the ones from my 2000 4Runner about three years ago and they could use a repaint now. The paint lasted a long time. I simply washed them in Dawn dish soap and painted.
I repainted my millenium silver bumper and used the excess paint to finish the hub caps. I just lightly sanded, primed, and painted it. They look great and it has held up for the last month they've been on.
I agree 100%. The regular Rustoleum silver metallic is a great match. You would be hard to tell it over the factory color. shoot the center caps with some Bulldog adhesive promoter and then the Rustoleum.
Like this one?
Rust-Oleum 7271830 Metallic Spray, Silver, 11-Ounce
https://www.amazon.com/dp/B0019K1YD2/ref=cm_sw_r_cp_apa_qfTNxb1CXRCBC
Or this?
Rust-Oleum 1915830 Metallic Spray, Silver, 11-Ounce
https://www.amazon.com/dp/B000PQGE2M/ref=cm_sw_r_cp_apa_djTNxbRS0M9R2
Sent from my Nexus 5X using Tapatalk
Like this one?
Or this?
[You ninja edited and fixed the link while I was posting!]
I would guess the first one is the right one. The second is more of a shiny mirror chrome.
Might be good to touch up my chrome rear bumper though.
First try, did ok
I pulled the center caps and washed them inside and out with dish soap and warm water this past Friday.
After they air dried over night (yes I drove around without center caps) I hit them with acetone to loosen any remaining paint - there wasn't much, but the acetone didn't do squat.
So I hit them with some 2K steel wool and got a bit more paint to flake off and figured that was it. Cleaned with isopropyl alcohol and let air dry once again. Yep, still driving around with naked centers ;):
I made up a painting jig using a lazy-susan type rotating spice caddy covered in paper with an empty cream cheese jug taped on top, so I can rotate the center caps while painting. Placed that on a small bucket and went to work.
I hit each cap 3 times with the adhesion promoter then three coats of the silver metallic paint (all per instructions on the cans). I noticed some of the old paint starting to bubble up under the new paint but was like F-it and kept going, figuring I would have to redo this at some point anyhow.
Here is how the caps look on the car after letting them air dry over night.
I plan to paint the Toyota logo centers with a brush and some dark grey paint someday
They look fine to me. I might have to break out the lazy susan next time I paint mine. I have one from Goodwill holding chemicals in the garage. You must be an engineer.
Hahaha, engineer no, I'm just a lazy yutz always looking for the easy way out
I was impetuous and and over zealous; the shame is overwhelming.
Do you think I can spot sand the offending areas and reshoot, or should I strip completely and start over?
Just rough it up with sand paper, clean with mineral spirits. Hit it once with primer & another coat of paint.
I put mine in the dish washer to get all of the dirt off & then lightly sanded. Acetone is for metal not plastic.
Yep, hit the high spots with sandpaper so it feels smooth to the touch, a coat of primer, and another coat of paint.
delislerebecca
