Panhard drop bracket
mkruse7678
Hi Guys,
I looked around and did not see anything for this. Do any of you run a OME or any other 3" lift with out the drop bracket? Any problems or do I need to have this? Thanks for the help. Also can I run the 3" lift with out the break extension. Thanks guys!! Mike
Nope, its not needed. Your axle will be off centered only slightly. Its hard to tell unless you really try hard or measure. I think mine is only ~.5 - 1" off.
If you stay at about 3" lift in the rear it wont be off too bad. I have 3.5" lift in rear and its off less than 2". I think its just a waste of money since once you add the bracket the rear is still off. You need an adjustable panhard bar to get it perfect but then you have issues with driveshaft hitting gas tank during flex.
H.Sikina
