Papadop88's 2020 TRD PRO Build
excellent final product :reddance:
can you post a side profile shot of the truck, would be nice to see the fit of the tires from that angle.
Can you post a pic of the sliders looking down at them? Wanted to see if they can be used as a step.
I can tell you that using them as a step is just about impossible. They are so tight against the body that you can't really get your foot on it. You can pretty much only get your toes on it which could result in slipping and busting up a shin bone or knee.
Maybe its different on a stock height truck, but with mine being lifted, if you're going to try and put your foot on the slider, you might as well just go ahead and raise your leg another inch or two and just put it on the floor board and pull yourself in.
Papadop, for Morimoto XB headlights..does auto headlights option still works as factory setting?
Maybe gSwift can chime in?
I'll try to snap one tonight, but they technically can be used as a step, but because of the angle, they sit up pretty high and there's not much real estate. Hence why I love the look of them because they fit close to the body. Trailrunner has photos...take a look
ShrockWorks Rock Sliders Install and Overview - 5th Gen 4Runner
Here ya go...I think they're perfect in the rear. Wouldn't want to raise it in the rear anymore. They're tight in the front on the stock Pro suspension due to the extra sag of the bumper and winch weight. So looking to raise the front up 1.5-2" and that's it. I don't like trucks with too much lift and tires that are flush with the fenders or sit inwards. They kinda look weird.
Did your truck come with the LED fogs or is that aftermarket?
You going to just do a level or a full lift?
Those are the mathcing Morimoto LED fogs. The 2020 Pro also comes with LED fogs but they're silver and not black. Light output is the same as I believe the Morimoto and the OEM are the same from straight looks. One is silver housing and the other is black housing.
Just looking to level out the front with the new Eibach spring for the Pro shocks. I like where the rear sits now.
Sliders
Thanks, I have Mobtown on my Taco and my wife can use them as a step. Looks like shrockworks are tighter to the body.
Gotcha. My 2017 came with halogens and I just replaced them with the OEM LED ones, but with the black housing. They look identical to the Morimoto fogs you installed. Well, except I put yellow filters over them - 5000k just doesn't make any sense in a fog light.
So open to other's opinions on which suspension direction I should go in...
I originally was debating between King, Icon or staying stock with Eibach's new spring for the Pro suspension.
After talking to the suspension guys at GAS, as well as reaching out and speaking with Accutune (some of the best in the off-road suspension tuning game, who sell Fox and King), both parties suggested I don't go with Kings. GAS skews Icon. Accutune skews Fox. Both acknowledged that all three brands are amazing no doubt, but each had their preferences and each said no to Kings for my setup.
According to both, Kings will ride like butter but they're also very finicky and will need rebuilding much earlier than the other two. Icon is solid and Fox seems to be the most durable in terms of life before having to rebuild. Icon will ride slightly stiffer than Fox.
Again, these are the opinions of these shops from their experts who tune and install countless rigs.
That said, since this is a daily driver, I will not be going with King, although I really wanted them. I also don't want Fox, reason being I currently run the Pro Fox's and if I'm changing out, I'm not changing to the same brand...personal preference.
So I guess it comes down to Icons with rezzies in the front...or Eibach's new spring for the current Pro Foxs. Because of the weight of my bumper/winch, I'm scared the Eibach spring won't be heavy enough (600lb spring rate) to hold the front without sagging. Also, the Icon system will allow me to fully adjust height and eliminate any lean...
Anyways, thought I'd share and see what you guys thought as well based on your real life experiences. Thx
I'm on mobile so search does nothing. There was a thread last year something like mods you have regretted. I was surprised when so many said if they had a second chance they wished they did not go icon and most wished they went Kings..no personal experience, just a thread in this forum I saw. I'll try search when I've the time and on desktop
This is just me but I would throw on the Cornfed spacer lift since your Pro fox suspension new brand new. Cheap lift and Gswift was very happy with the spacer lift. Unless you have the extra money to upgrade I think you will always get different opinions. I would check with HeadstrongOffRoad and see if Maria still is handling the ordering. She is very knowledgeable that’s where I got my bilsteins for my 15 Tacoma years ago. And see what she suggests.
Check out [MENTION=152841]ehcanadian[/MENTION]... he has some brand new in box Icon extended travel with CDCV and 700# spring that would possibly work with your added weight. Its a pretty fair deal too it seems like. He has them posted in the 5th gen Sale/Wanted thread
Coils don't cost that much if you need to change them. When you are paying King and Ikon prices for suspension, the cost of changing coils is not all that much.
My advice to you is to stick with your Fox, which is excellent quality. If and when you actually have front-end sagging, then address the spring issue.
In the meantime, if you want to lift the front up 2" on the cheap, spacers will do it. I had them in mine and they were faultless. Very easy, can always remove them too.
I saw his listing. I would have snatched them up, but they're 700# springs. Way to stiff for my weight. According to the shops, 700# would make it too much of a stiff ride on the pavement. 650# is the sweet spot.
tssawlson538
