gman72
I've been 5 years without a decent parking brake, wouldn't hold whatsoever. It was brake time anyway so I just installed new rotors in the rear, new pads and new parking brake shoes.
Adjusted the parking brake per the Toyota procedure (tighten via the screwdriver/adjuster hole in the rotor) 'til it holds, then back off a bit 'til wheel spins freely. Well, it didn't do much, pedal still easily went to the floor. So I took out the center console and adjusted the cable. Pedal is much more stiff now and seems within the 5-7 click specs or so ... but it just seems to me that the brake is still very weak.
i.e. If I put the truck in gear it just rolls away with the brake on, I would think the parking brake should be able to hold at idle no? Anybody else with a V-8 can test theirs and let me know?
