Parking in single car garage
You live in the Bay, what do you expect!?! Unless you have an extra 5 figures a month for rent. Well depends where in the Bay area and how risky you want to live...
Won't be here much longer... off to greener and cheaper pastures... with a garage
I back in mine, single car garage, with 1/2" to clear the side mirror of the door on each side. First week I got the 4R, I had to move back and forth many times to get to the perfect spacing, scratching the mirror in a few occasions along the way. 4 months later, when I thought I got the hang of it, the garage door took the shark fin off and bended the roof because it was not opened tall enough. A $2000 lesson.
I back mine in the single bay of my 3 car garage as well. My garage has extra storage space on the far end though, so when I swing the driver's door out, I have tons of room. Hardest part is making sure to back up perfectly straight, like a couple of other people have mentioned, the mirrors are a tight squeeze. I use my mirrors to help me back in though, so I don't care that they don't fold in electronically!
Not all single garage stalls measure the same dimensions and the same goes with two stall garages.
The house I just sold had the double and the single separated by a load bearing wall and getting two vehicles into the double using backwards/forwards/split was always a nightmare and the single stall was barely 8' wide.
The new house we bought has a double stall garage larger than the combined 3 stall garage we left.
I think it has to do with when the garage was built and the relative size of vehicles at that time and/or the relative cost of a square foot of space on that lot.
Only issue for me parking in the garage is height; but I'm on 35's. 3" lift, and the Pro rack doesnt help. Vehicle length is not a problem at all; I even have 5 bikes hanging on the wall in the same bay I park, and have a standard length garage.
One trick I used when I had a tight garage was mounting an old, cheap pillow to the wall or other obstruction. At least if me or anyone else opened a door wide (it's going to happen eventually) do damage is done. Currently, my garage fridge door will bump my 4R and I wrapped the handle with a thick microfiber to prevent it was dinging the truck if opened too far.
I also moved my tools to the basement. It amazes me how small some of these garages are on newer homes.
Sent from my SM-N986U using Tapatalk
