Part a 2000 LTD 4WD and 1999 4WD SR5 - Mid Atlantic (NC)
Looking for the rear hatch license plate bezel and the "gasket" piece that fits between it and the body. Pic attached as an example. Need the plastic mount points (in back of it) for the key lock cylinder to be intact.
MI 48879
Sent from my SM-G965U1 using Tapatalk
i need all the mounting for the radiator. The metal vertical pieces that holds the radiator to the body, and the square nuts/bolts that those pieces bolt to on the radiator. There are 4 square nuts/bolts and also need the bolts that hold the shroud to the radiator support pieces.
Basically all bolts/nuts/mounting hardware for the radiator that can be taken off the radiator/shroud assembly
i'm in NC as well.
Hey man, you still have parts? If so I need a 4wd auto shifter and bezel. (SR5) I don’t need the limited one, it’s just for photo reference to what I’m talkin about.. Photo below. Thanks!!
Studs, Washers, Nuts
Looking for the 4 studs, washers, & nuts from the output on the transfer case. These are in the companion flange on the back of the transfer case to bolt the drive shaft to. Thank you.
MI 48879
Hello,
I'm sorry for the very delayed response. I actually wasn't getting notifications for a while and this totally skipped my mind. Are you still looking? I can check to see if I have a good one if you are. Thanks!
Sent from my SM-G930V using Tapatalk
I'm sorry for not replying sooner. I do have them if you are still interested. Take care.
Are you still looking? Sorry for the delayed response.
Hey, I am just a few miles from you in NC.
Have any A04A 4.30 elocker setups? front diff clamshell and full rear axle
