Passenger side lean
Bloody14KDSS
Hello,
I just arrive back in the US. I was overseas on a job. We'll, I was looking at my 2014 Trail KDSS & it have a huge lean to the passenger side. What could that be?
Thanks in advance.
My guess is that your gas tank is low. Fill it up and then take a look at the stance.
2014 Warthog Previously said:
Apparently that is the normal stance for the KDSS equipped 4runners. No KDSS = Driver side lean
This is also true!
This is also true!
This is the normal stance for the KDSS ones? Full tank, empty tank, the same thing. Lean to the left. It borders me like hell. It drives normally. I just go crazy looking at it. I'm even considering trading it in for a non KDSS one. R u sure the lean to the left is normal on KDSS ones?
I did but there are so many answers that I don't know what to believe. Plz help me if you can. Thanks.
Have you measured the lean?
Have you confirmed it's not that spacer lift?
Have you driven it and then checked the lean?
Have you measured before and after filling up?
Have you taken it to the dealer?
Have you checked tire pressures?
A bit more of 1/2" rear. I have check b4 & after filling it up. It's not the lift. I re-checked. Tire pressure is even both sides. I'm not going to mention it to the dealer. They said that I would lose my suspension warranty if I have this lifted. The dealers are freaking pirates. I did read about it b4.
http://www.toyota-4runner.org/5th-gen-t4rs/152734-2014-trail-premium-right-side-lean.html
I'm just not sure how to fix it or if there is any real fix. People talk about this been normal on KDSS models. Others say it might b a coil size difference. There are so many answers that one don't know what to do.
No factory fix as 1/2" is within spec. Shim your spacers if it really bothers you. Mine leans...sometimes and sometimes not. I never have it on level ground and if I do I am in it so no big deal and I know nobody else notices...or cares.
images
tuṣṭāva
