Passenger side lean
Damn. Why didn't I think of that. I guess that's the fix.
Or
You guys just want me gone.
Ha :D
Don't let the snarky comments get you, they are almost always just good natured ribbing :)
You could try taking it to the dealer and see if they can recalibrate it for you, it might improve things if for some reason yours was WAY over to the passenger.
In fact if you have NOT had your KDSS recalibrated after the lift was installed, that may be the problem. Have the dealer do it or you can search for instructions and do it yourself if you dare ;)
I think they are joking around with you because there isn't much of a fix. Heck compared to my last grand Cherokee it sounds like you are pretty level. Some trucks have it and it's not just a Toyota thing. If you had coil overs you could adjust for it probably but even then some on here seem to still have it.
OK OK ... on a serious note. It is because of the transmission fluid. Just start draining it until your rig is level and viola!
Hey guys!! This one is smart!
But in all seriousness I have a small lean as well, it seems lifts might exaggerate the issue. Trust me brother I worry about little things on the truck too. Good luck!
Thanks a lot. I guess I should let this go... For now. Lol
I don't have KDSS and mine leans to the driver side by a half inch or more. I try not to think about it much or I would definitely obsess over it.
tuṣṭāva
