WCVanHorne
So I've been though lots of mod threads but haven't seen or have missed exact illustrations of alternatives for routing a fuse tap wire out of the fuse box under the hood.
Several nice secondary fuse boxes if one is going to go all out adding accessories but I'm probably just doing the one cct for the foreseeable future.
As I didn't want to hijack a build thread or perform thread necromancy I'm posting this new one just to see if there are any alternatives suggested.
My current plan, which you can pretty much see in the photo below, is to drill a small hole in the side, just below the lid lip, in the well formed by the bolt. I will then put in a rubber grommet small enough to get a reasonably water resistant fit around the 14GA wire I will thread through and run to a relay.
Any other ideas? Warnings? Suggestions?
Note the blue crimp on the red wire off the is not used. I will be clipping it shorter and splicing on the end of my wire run out to the relay. It is just lying there for fitting and planning.
