Chris Sandstorm
Well, today was a good day..Finally got the 4runner off the blocks..
Started replacing suspension on Sunday, had to also remove the XREAS stuff...
Did the rear first with OME 80 series shocks (60020) and Toytec Superflex coils..
Then up front dropped in my ICONS and LR UCAs, one of the ball joints was loose, so the great folks at Specialty Products in Longmont Co..Were very super and warrantied my just over 12 month old wheel bearing...Thank You Jeff!
We decided to grind the larger calipers down a bit to fit my TRD 16 inch gun metal wheels but.....we needed to grind so much to get them to fit that when we tested the brake pressure, we blew right through the thin metal with brake fluid....
So we replaced with the smaller rotors and calipers and the 16s fit perfect, also decided to throw in a new set of Sumitomo's upfront and wrapped it up this afternoon in time for lunch at Jimmy Johns...
I am super happy with the look and feel of the set up. The ToyTec coilovers give a hands down better ride then the OME 895s I had on my FJC.
The 255/85s rub just a touch on the mud flap when turning, so tomorrow will do some trimming. The spare is snug and will have to let the air out a bit to get it to fit without too much rubbing on the swing arm.
The first weekend..wahsed, removed the side steps, installed Lower Links, skid plates from FJC...
Today...
Today...
