[pictures]...Bridgestone Dueler A/T Revo
Nashvillerunner said:
Awesome end result!!! I have a silver 4runner also and that will be the tire that I go with!!! What are the next plans for your 4runner???
That is exactly the next mod I am going with along with the Revos!
lawwailok said:
nice nice!!!! looks a lot more beefy than stock size! any rubbing issue?
No rubbing at all. The only know rubbing issue is from the BFG, because of their squared shape tread.
I have been debating new all terrains myself. These are slightly larger than stock. Have there been any issues wheel rubbing etc?
Mortie[/i] [b]I have been debating new all terrains myself. These are slightly larger than stock. Have there been any issues wheel rubbing etc?[/b][/quote] [QUOTE][i]Originally posted by K.C. said:
What he said...
Looks good! I have the same tires, as for rubbing, only when I turn a tight radius do I get the rub, great tire I have been on them a little over a year and they still look new. I just had them rotated at the stealer and the wear was minimal after 9K.
Nice tread pattern on those tires.
As I've said before, I currently have the Yokohama Geolander A/T's and they really suck on snow.
These Duelers are a candidate if BFG doesn't start making the A/T KO's in the stock size before then. As of now, they only make the stock size in load range E which I really don't want to go to.
**UPDATE**
I too have this exact same minor MINOR rubbing on the inner liner.
I didn't do anything about it...I just left it as is.
Will go at it if I ever get larger tires.
Stock
IMG_2555.jpg~original
Slightly Modded
IMG_1141.jpg~original
(October 15, 2009)
• Daystar Spacer Lift 2.5/1.5 (Preload/Topout)
• P265/70R17 Bridgestone Dueler A/T Revos
...for now
Daystar Spacer Lift
2007 Toyota 4Runner Sport Edition Lift
thank you J.A.
Daystar (Spacer) Installation On 4Runner w/XREAS
Daystar (Spacer) installation on 4Runner with XREAS - Toyota 120 Platforms Forum
thank you bulldog
