Pikeman Build #2(I am back)
Welcome back brotha! Glad things are turning around for you and your family, its hard hearing about fellow members going through rough times.
Sorry I missed the April Run. I have been working 14 hours a day 7 days a week.
Status of vehicle now is I am using as daily however still some minor things before I can off road.
1. Transfer case input shaft seal and bearing to fix a bad leak.
2. Ball joints to fix clunk in front end and avoid catastrophic failure.
Then to enjoy until I can do suspension and other build items. She runs really good and drives nice and in town with a 15 mile commute getting 16.5 mpg and 20-21mpg on my longer runs into civilization.
I definitely understand bro, I took a promotion to manager that takes a lot of my time too...but not quite 7 days a week, you are a beast to pull that off. Let me know if I can help.
Sent from my SM-G900P using Tapatalk
Long time but more progress
Okay so after getting the engine in and driving a little bit I found the transfer case and front diff. were spewing oil everywhere. I parked it for several months and finally worked on it last month. I pulled the transfer case and front diff and replaced all the seals. I have been driving it for about a month and it is running great with no leaks so far. I had purchased a cheap $70 lightbar to mount on the bumper and found a guy with some Tundra Wheels in Havasu for real cheap. Still no suspension or armor but here is how she is now.
Thank you. Trying to work on this when I can, hoping to keep making progress now that I got the leaks fixed and using as a daily driver.
Still very slow, especially now that my Contract ended and back to looking for work. I just installed new plugs yesterday and will be installing new fuel filters tomorrow. I also put on new stock sized shocks since I do not have the funds for my lift yet. I sometimes get a random CEL and codes that do not correlate with how the vehicle is performing. Also sometimes my scanner is not able to connect/ communicate and read the ECU properly so thinking of replacing the ECU or sending mine to have repaired.
