...little info.
If you drain the block, the passenger side is fairly easy to get at, on the v6.
The driver side is a straight up pain in the butt to get at and not hardly worth the 1/3 cup that comes out after draining the passenger side.
Makes alot less mess draining the passenger side too, if you plan to pull t-stat, hoses or anything on the front of the engine.
Yeah I used wobble extensions, like a 10 and 6 inch and had zero issues. It is in a sucky place though.On the V6, with a long extension, gimbal, and 10mm socket you will get the driver's side block drains w/out much difficulty
