pink cooler
Emman
it is normal after few hours after the engine off the cooler pink (antifreeze) down to the low gauge ? when I turn on engine the cooler up to the middle ....
should I put more pink cooler ?
You have two marks on the resevior. The highest mark is the maximum mark to avoid "boil-over" when hot, and the lower mark is the minimum or LOW mark. I would suggest filling to the upper mark when your engine is cold.
Good luck
when the engine is hot the cooler up or down ?
because when my engine is cold the cooler is at the low mark and when my engine is hot or run is in the middle...
Fill to the middle, drive around check level. It should be at the upper mark when HOT.
ok thanks
where i can find pink coolant ? just dealer have this ?
it's a mix or i can buy one bottle ?
Go to the dealer, and then you don't need to worry about buying the wrong type. You'll have it forever unless you are leaking coolant. It's a mix of antifreeze and water.
