Pj Benn's Hawaiian time maintenance and build
Thanks, getting something that had the factory look was important to me. This the camera. Working great so far. Only issue I had was the instructions said to cut one of three wires if you don’t want back up lines. The instructions had wrong color listed so had to solder and try again.
Fixed the locker this morning and re-installed the Sonoran steel sway bar brackets. Checked torque on some other bolts while I was back there to try to get rid of a squeaking I get over bumps sometimes. Started to replace sway bar bushings up front but end links were corroded where the bushings sit. probably gonna order some new ones first.
Need to order new front diff and steering rack bushings. Not sure if I should go poly or not. I hate weird noises and worried they’ll squeak
Ugh. Assuming my alternator is shot. Fuse blown, this burn and no accessories or start
Tried to do some maintenance the other day, ended up deciding to buy more parts first. Should have tried to start figuring out how to install a new upgrade instead. Will have some time off around the holidays, hopefully can get a lot done then
Changed out my steering rack and got to work fitting this
Still need to run the switch wiring and I might remote mount the air filters.
Happy New Year!
Brah! Did someone really tax your cat? I thoughts prius's were prime targets but a 20yr old runner:wtf:
Yup. Been hitting choke people’s cars. Got it fixed but with aftermarket cat and muffler. Gotta give a little throttle now in sand where it used to almost idle through
Been hearing how bad it is there now.
Damn thieves taxing the hard working people of Hawaii.
The scrap metal yards (the shady ones) are part of the problem.
Gotta support da BATU action. Sorry to hea my bradda. It’s not only back home dats happening up hea I Washington too. Plenty chronic everywea
Still mostly just boring maintenance stuff.
P0753 shift solenoid A electrical popped up twice recently. Searched around and it seems like nobody with the same code was able to figure out what specific solenoid of the 3 in the trans it was. Hoping someone who reads this might know.
