Plan drawings for outside of 2008 T4R ?
jdkilroy
Does anyone have plan drawing for a 2008 (or 4th gen) T4R ? Specifically, the roof so I can get the roof lines and exact distances between the roof rack attachment points.
Thanks, Jon
No not yet, not sure the dealership would have it but then again if they don't who would? Toyota Japan... ?
Not sure who would need something like that other than someone trying to design an aftermarket accessory that fits well.
Jon
Here is the distances between each mount:
Mount-measurementsv2.jpg~original
I took measurements of the roof curvature when i was designing my roof rack, unfortunately, I don't have it written down anywhere. Sorry.
Remember that when you design a roof rack (my assumption) measure the curvature from left to right as well since the center of the roof is higher than the edges. Minimum mount height of you plan on building a flat rack should be around 2".
Are you using a software tool to design the rack? I might have some .dwg drawing on my backup hard drives. Not likely, but i'll take a look if it would help.
Thanks for the reply Kevin,
Any chance you could email that drawing as I cant really read numbers on here.
If the .dwg drawings are handy it could only help. I will confirm roof curve measurements/offsets on vehicle myself but it appears you and I have same year T4R.
Thanks for your help, Jon (jdkilroy at earthlink dot net)
