Plasti dip fog light bezel
mkeegan27
Hey all.... I recently dipped the front and rear emblems and wanted to spray the fog light bezels as well. Has anyone sprayed them without removing them and just peel the over spray? I can't seem to pull them out due to the lack of something to grab on to. Suggestions? Dzięki!
I plasti dipped the fog light bezels on mine a few months ago. I took them off and from what I remember there are some tabs on each corner of the bezel. I used a flat head screwdriver to pry the bezel a little and then reached under the hood to feel for the tabs and pushed them off each slot. It's a tight squeeze to get your arm in there, but I couldn't get the bezels off any other way without feeling like I was going to break the tabs. You could probably plasti dip without removing the bezels and just tape around them and over the bulbs. You'd just have to be sure to tape it off real good so you get clean lines to peel off the excess dip.
I actually just went and bought the black ones from my dealer and replaced them myself. Use a flat head screw driver, but be careful and take your time. I wrapped my screw driver in painters tape so I wouldn't scrape anything. You can see them in my build thread. It's about all I've done so far. I love the look of the black ones.
thanks everyone for the replies! i ended up removing them...much easier! I will probably get the trail ones down the road depending on how these hold up.
