Pleasantly surprised by the TPMS
xxaarraa
I didn't realize my 08 T4R had an indirect system and that it actually works. I am coming from a Tacoma which had a direct system that was a pain in the ass and I had assumed the same for the runner, only to be pleasantly surprised!
I moved my non-TPMS-valve-stem Tacoma wheels/tires over to the T4R when I bought it. Oddly, the TPMS light never came on and I thought the entire system must have been disabled or something. Then yesterday, it came on while driving home. I thought it was odd that it just came on and figured "well, time for black tape I guess" Then this morning, the front tire was completely flat. Once I got the tire fixed and remounted, the TPMS light went away, indicating this is some sort of ABS/speed sensor based indirect system.
I personally like the indirect systems better for street use, have had good luck with them in other cars. Woohoo for the runner!
The '08 doesn't have an indirect TPMS system... all vehicles produced after '07 are required by law to have a direct TPMS monitoring system.
Now as to why your 4Runner seems to be acting like it has an indirect TPMS, I honestly have no clue... but as far as I know, Toyota didn't set up a redunency that goes to indirect TPMS when the direct fails (though, that would probably be a good idea).
The indirect TPMS systems were not bad systems, but were often plauged by improper repair/maintence, lack of understanding, and sensitivity to tire/wheel combinations. Part of the reason they went to direct TPMS units after '07.
All vehicles are required to have TPMS, you are correct. But I am not sure if the law specifies a particular technology (direct vs. indirect). I know for a fact that my wheels don't have TPMS valve stems and the 4R TPMS light lit up when the tire was flat and went away when I got the tire plugged and inflated. Definitely indicates an indirect system.
My '05 is a direct system..... and this topic is kind of boggling my mind.
youngrk
