Blackwatch
Anyone have any ideas on how to best clean out the frame? Lots of debris up in there.
Good luck on the repairs, I hope it goes well!
As far as 3-4 years down the road and dumping $40-$50K into a total restoration, I would instead invest that money into another 4th Gens that has a good frame and low miles for about half that much money with plenty left over to do whatever upgrades you want....or for that much money you can get a low mileage 5th Gen.
I do this type of work for a living and $3500 is not far from where I would charge for something like this. There will be many different opinions as to what you should do. However I would recommended if you do decide to fix it to fix it properly this time so you do not have to keep bringing it back to be fixed. The most concerning hole to me would be the one which looks to be on the rear bumper reinforcement. If it’s rotted behind the plastic bumper cover it would need replaced. I worked on an 08 last month and it required dropping the fuel tank and spare tire to get to the problem areas. The front frames near the control arms are very common. The safetcap frame sections are the way to go in my opinion unless you do a full frame swap. However the rear bumper is only available from Toyota as far as I know. The best way to clear the frame of the silt you’re talking about is when it is repaired. If you go to a good company they will clean it out when preparing the frame for the new sections of frame.
The possible reason for the safetcap recommendation on the driver side is the people who work on vehicle frames know, if you’re going to fix it, fix it properly the first time. The hole may only be the size of a quarter but once it is being worked on it generally expands, being as the vehicle has been exposed to road salt for many years.
Thanks for the insights. Why would you say the rear frame hole under the rear bumper is more dangerous than the front A-arm hole that runs the seem?
Any opinions on using adhesive bonding to fix small-medium sized holes? There’s some new information out there on the strength of new adhesives.
Any thought or prior use of these types of fixes?
To everyone:
Any suggestions on a quality frame/weld shop in Northern, VA that would do this job RIGHT. Hopefully at a reasonable price. I want her to last for a long time. Greatly appreciate everyones support. I love 4th gen owners. We're all in this together!!
[MENTION=1857]fourwd1[/MENTION]
I appreciate the insights. I want to have this fixed right. The guy I took it to showed me some examples in his shop of their work. It looked really good. He said they charge $3-4k, however thats because they take off a ton of stuff to do it right. The new coating looked like a thin Rhino Liner over the whole frame.
I guess my issue is a) I would like these two holes fixed before the winter so they don't get worse (and peace of mind), and b) the cost to do the whole coating is pretty expensive and not sure I can afford that yet.
[MENTION=68364]04rnr[/MENTION]
Do you have a link to these items? Thanks
Welcome back to the gift that keeps on giving. Yes, our good friend Rusty the rust bucket has reemerged.
I paid a guy last year (almost exactly a year ago) to fix an A-arm rust hole and por-15 the frame. Unfortunately, the gentlemen did not take his time removing the rust and, therefore, the por-15 coating has not held up or stopped the progression.
So, here's my new hole. It's an interesting hole. Because this hole is double sided. It is located inline with the front cross-member that is directly under the front doors. The hole is on the outside of the passenger side frame (where the door is) and there is an inner hole that can only be viewed through the outside hole. This is because the inner hole is directly inside the cavity of the cross member, so the cross member metal is still good but the space that occupies the inside of the cross member, on the inner frame has a hole. If that makes sense.
Yes, a mouthful and hard describe, but take a look. My welder from last year hasn't responded about fixing my new hole. Im worried that the inner hole would be hard to address given its location and proximity to the cross member. My guess is to cut the outer hole fairly large as to fit tools inside the frame to address cutting out the inner hole, without compromising the integrity of the cross member.
Very confusing to me but I'm sure a professional welder sees a path to victory, hopefully.
If you have a V8 (maybe V6 too) the AC condensate line drips right on top of the frame rail inside the engine compartment, passenger side, and the condensate collects right under the passenger side front door and drips on the ground. While doing that it rusted your frame just as you are seeing, many have reported this issue. Reroute your condensate line away from the frame.
Im generally not an alarmist with rust, and think most people make too big a deal of little rust spots and surface rust. However, if youre having to weld now multiple areas of the frame, it might be time to let her go. I agree, probably possible to fix, but how many other spots are waiting to develop (radiator support, the rear cross member under the bumper cover, above the spare tire)
Yep, this is definetly the biggest problem 4Runner owners face who live in the rust belt, it is an ongoing never ending job.
Anyone think it’s worth it? What’s the value of V8 limited 197k that mechanically has been VERY well maintained, but with frame issues?
Got under again today. That hole has a top, bottom, and inside parts of the frame rail. And it’s all around that cross member so I have no idea how they would patch that because that cross member is welding right there.
I feel as if I go forward with this rig I have to replace the frame because this problem will NEVER go away. I thought I saw somewhere a dealership that did a swap on a Seqouia and the owner said it wasn’t too bad.
