Please help!
Daron-t4r
I dedicated today towards installing my toytec ultimate lift, and I've run into a bunch of problems, two of which I was wondering if any of you had the answers to. 1st, I discovered I have XREAS, but I never bothered to check for that, it was leaking anyway, so that problem has been dealt with.
However, which taking the top 3 nuts of the top of the coilover, I found that there is pretty much 0 room to get even the smallest socket wrench back there, why is there so little room?
MOST IMPORTANTLY: Taking the coilover out was hell, had to use 3 cro-bars and finally got it out, but putting the new one in is even worse, I can't seem to get the lower control arm low enough to have the coilover slide in, help!
Have you tried loosening the eccentric bolts on the control arm? This should allow the lca to drop down abs you'll have plenty of room. As for the three top nuts, a ratcheting wrench is a life saver.
Solved the second problem, Did the left side, and finishing the right right now, back is done... ratcheting wrench has been a life saver, but its still a ***** to get out!!!
Well, considering I've never done anything of the sort, it went pretty smooth, If only the impact wrench hadn't given out on the first go, we would have had a better time, but oh well. Took about 6 hours, working very slowly, and taking pictures of everything for when my brother does the same thing.
Build thread to come soon.
