Plug and Play Rear Camera Override Dongle
Assuming you used a DPDT switch would that mean just one switch instead of two? Or still one separate one for power? I plan on modifying dash to accept otrattw switches.
Yes one DPDT switch could be used rather than two spst. The overuse would be wired to both throws on one pole and the camera toggle would be on one throw on the other pole.
SO. If you are absolutely sure you've wired everything correctly, and still can't get it to work, take a look at the fuses. I initially had things quickly wired up by hand and it all tested out perfectly. I went to solder all the wires together and buttoned everything up nice and neat only to find that the switch no longer worked. After ripping everything out and spending the next five hours trying to figure out what was going on, I came to this thread and saw someone had mentioned a fuse blowing. I checked the same fuse and sure enough, it had popped.:bash: I disconnected the battery this time. Replaced the fuse and redid all the work and I was back in business in less than ten minutes. :banana:
This dongle looks great, the 4 channel video switcher looks good too. Has anyone thought about using this as a dashcam and wiring the camera to a small composite video dvr? It would be great to record front and rear cameras constantly but view them independently of the recording. Obviously this would require that they be powered constantly while the vehicle is on but it would eliminate my need for a dash cam. From what I can tell, there isn't any dedicated hardware so I would need to build something with an old laptop or raspberry pi. Has anyone gone down this path and found something better?
I would be interested in this as well. I love having a dashcam, but I wish it was front AND rear recording as well as controllable or at least viewable through my head unit.
There are small vehicle DVRs out there on the market, i have seen some on Amazon. As long as the unit has a composite video out you can use it in conjunction with this and view the video on the factory screen.
UPDATE!!
https://www.amazon.com/dp/B01NCNCFHR
The new and improved model is now available and is also now available for sale on Amazon (Link above) and as usual on my website.
Product functions as it always has but now has 4 feet of wire attached and protected in a braided sheath giving it a much more professional install look. Also from now until the end of the year all orders of the override dongle are 20% off.
Trying to build up the amazon store and offer prime shipping soon. If you are happy with the product or if you have purchased and are happy please leave a review on amazon! Thanks all for the support and have a happy holiday!
New pictures below:
_cRqdMlpSEkYr6PUT11tCOPida26PB31VymM7snSa9VSkyai49vPeF4mNwvDiq04pa7nM3HbWs0M8uAm9wqySPJQ1HJpYZ44LDMrNIFUXkD_qjRGOOCOaF5PsxN1nOMwQzGPvYsKnY-ac2cl6JoN2Yp9f-B1DuEMvVwpn_02NtFnPc6rBfWFg2SCod5BA6E5jCGJWPHg5cxYfxikV2cmQpnSMkw-ri1rGF0qo7NeiQpXHZ01v7zMfa4R3jK_Im2ld_du_HsLmraMXsdhNQ9JbTaLTE2RQAPJ-_i7cVe0m4tDGUTnAbjT75CsNlTfxJZ-xQObaSD_J6t30KJnrRpoOCHdLJBzdttkiHTz_yCzr5pEHrY3K1ntoe6Udj_rPd0377_UnzGF7dxI2HpIycV2HURQ631GNZYkLGZDFtwKYZbX7lTrybR5gYNhyqFu5axwCrFff0E3Wuqetx-IYSEsFKlEPyZKQB9Rd-kQ1hQ-5BtyJP7SrAM0JH-Uv5jGZmlSQSblqapMuXAJidv7z_rL2XrPgr-d8g8TIMWn8J9EkRuDdI5FVmJo0D7npxzhSRzVjZ93K2hIeHifuzgYRm2ZfaWrVvPGUaEb8b9bXI33fP1tj7jV7bQf=w668-h889-no
ZSQRwVb0SXjQfV5YV0afFGvN7pag0ve6WqgjYYxW-94mitGzJxe5ipsakQhMuNP9tNJMSFHYDVNT0QP2fh-MYcmoP_PO-Yt959iNmmq_87OYIVY-A_MaTgBgOcu-XGIfDYKIWeGciL8Ee9oHuHOvlyUVWn5LE5EABX3z0IpOhwRwIR9MtJfzOCt3sN6ka4rtY52dM-BsQaUdlYz_nSRFucDC6CoOC4ChVBuJodeVBNXKuQOKVW-VD8SUQJN_w6nq-jPiH091iF90wDdOiGIZT3SfNkW1397yc5hU9jEom-abl5aJYc1_64LtMSoHtrBf5sGI7L1nonLLpI4DdiG-SXmqGmkGS2m9gaAC1YgAX-Fvd3VUsPaiGyZxAS2lW7yvZAfD-y7sP1eUfzsLUihvs1SgX1ZoLu6C11SGud7ySCD-xgL_er9WNPYdtyhI5JtsSckYXXGZaORVxPEIKiJWZfBlBWHxylEW3Aja5EauSwjfcyhdN98-V70NW1VwkIekvzqKevJlwjDX4HUVJS39C0im5ljWKoJQ6eH6rDMmtwFOf-PmHAqE0rVlSkHyC0albAmN5QQmkcttCQqZ0emM6B9YI03Xz0OpsZCk7iP49Q5jFqd0=w668-h889-no
Finally got my front camera replaced with one that works, and now with the 4 way switcher I can see front, rear or both and there is room for expansion. Love your work man!
"Fun Wheel Drive"
UPDATE!!
Will you have Amazon Prime up before the discount expires?
Nice surprise! I have a some stuff in my cart I've been trying to justify lol - any chance of discounts with the 4 camera set up?
I'd be interested in this too. The new harness looks great, thanks for improving it and providing a discount!
On another note, the website doesn't seem to be loading for me. Just getting a blank white screen (and the old link from the original post gives an error message).
Interesting mod. Have you looked at incorporating a 3-way rocker switch, as opposed to having two separate switches (on/off and source select)?
I.e. https://www.youtube.com/watch?v=y2-d_9GkCb4
The way I'm thinking it'd work; up (select front cam), middle (default), down (select rear cam).
Not quite sure how to make that work wiring-wise, though. What do you think?
Yes a double pole double throw switch would work perfect to replace one switch. Only issue is there isn't one made (that I know of) that fits in the factory spot and looks OEM.
Got the override kit for Christmas and that on-off-on switch idea is what I have been trying to work out. Not exactly sure how to wire it either, but the front camera position would have to trigger both the rear override and the source switch at the same time. Can anyone help with a simpleton's explanation for making this work?
Sent from my SAMSUNG-SM-G900A using Tapatalk
Jhunt
