POLL! 1999 Cali Emissions V6 with Auto Trans Only
Read the first paragraph in the post before voting!
  • 09/98
    Votes: 0 0.0%
  • 10/98
    Votes: 0 0.0%
  • 11/98
    Votes: 0 0.0%
  • 12/98
    Votes: 0 0.0%
  • 01/99
    Votes: 0 0.0%
  • 02/99
    Votes: 0 0.0%
  • 03/99
    Votes: 0 0.0%
  • 04/99
    Votes: 0 0.0%
  • 05/99
    Votes: 0 0.0%
  • Total voters
    1
4eigner
Read the full post.
Please only vote in this poll if you have met ALL 5 of the following criteria:
-Model year 1999
-5FVZE 6 cylinder
-Automatic Transmission
-Under the hood Catalyst sticker states "...CALIFORNIA REGULATIONS APPLICABLE..." in the large box near the middle of the sticker
-THERE ARE/WERE 2 FACTORY INSTALLED CATALYTIC CONVERTERS IN THE EXHAUST SYSTEM
To reduce the variances and improve the accuracy of this poll we're going to only include the specific group noted above.
The purpose of this poll/thread is to determine when Toyota made the switch from a 1-cat to a 2-cat exhaust system in their 1999 model year Cali regulations compliant T4Rs w/ 6cly automatic trans. Let's attempt to pinpoint the month this happened. There's a good chance that the change happened within a calendar month so the last one picked will most likely have vehicles equipped with either system.
To find the month/year your 1999 T4R was produced, look at the driver door jam. You'll see a white rectangular sticker that shows "DATE XX/98" or XX/99 in the upper right hand corner. The XX is actually a number which refers to the month, and the 98 or 99 refers to 1998 or 1999 respectively. If you're voting in the poll, you will be selecting the number that matches the date on your sticker.
In the bottom right corner of this sticker it will show "MADE IN JAPAN" and have "NO.XXX" below it, where XXX is a number which most likely represents the production number for that particular month. We may even narrow it down to a range of numbers if we get enough participants that meet the criteria in this thread.
Part of the reason I created this thread is because of my air/fuel sensor woes. The following sites led me astray from the correct front air/fuel / O2 sensor for the 1-cat Cali emissions 1999 T4R.
Referencing Underdog Racing Development:
URD's chart (Oxygen / AFR Sensors - Underdog Racing Development)
Referencing Denso's website: (Find My Part | DENSO Auto Parts)
Multiple threads on this forum have also netted conflicting (but mostly wrong) information, stating that all Cali emissions Auto 3rd gen T4Rs use the Denso 234-9002 sensor prior to the catalytic converter; this is false. My 1-cat Cali emissions T4R will not accept this sensor. I don't wish for anyone else to waste money by purchasing the wrong & much more expensive sensor like I did.
Now, instead of stating to just buy the 234-9002 sensor if you have 2 cats and 234-4162 if you only have 1 cat, let's expand our knowledge of 3rd gens and find out when the swap happened.
I dont think engine or tranny matters. They all switched to 2 cats at a certain point. I will refrain from voting.
Built in Oct 98 - 3RZ -5 Speed - 1 Cat.
Why do you only want to hear from owners of 2-cat '99 Runners, which are the vast majority? I'd think you would want to find the rare birds, which are any '99 one-cat Cali. 4Runners. What month was yours?
Also, why no love for us 5-speed owners? Manual cats matter, too!!!
(03/99 5-speed Cali V6)
Are you SURE you are a Cali. emissions truck? I'd love to see a pic of your sticker.
For the record, I have always told people to either count cats or look for the A/F, TWC(2), HO2 (Cali.) or HO2(2), TWC (Federal) on the emissions sticker right under engine family to determine what sensor to order. Those labels are very confusing and you may not, in fact, be a Cali. emissions 4Runner if you only have one cat.
The reason I chose the configuration that I did for the poll was because I presumed that the '99 6cyl auto trans with 2 cats was the most prevalent of configurations on here based off of what I've seen browsing the forum for the past couple years. If I'm searching for a unicorn, it'd be more difficult to get data points on it with fewer (if any) on the forum. If it turns out that 2 cats were present all months, it'll either show that my premise was false, or that they coexisted from the starting month or earlier.
I'm not hating on any particular motor or transmission :p. I just wasn't sure if they were on a different assembly line or not. Not knowing if certain configurations received the exhaust changes at different times or not I opted to keep the variables down in an attempt to have a "control group".
However, in light of your post I'm pushed to question whether my poll has any validity. Do ALL Cali & Fed emission stickers have "CALIFORNIA REGULATIONS APPLICABLE" printed on them? This would certainly make it ambiguous & confusing.
If I'm making sense of these codes... the A/F, TWC(2), HO2 (Cali.) or HO2S(2), TWC (Federal)
A/F = Air/Fuel Sensor (wideband)
TWC(2) = 2 Catalytic converters
HO2 = O2 sensor
HO2S(2) = 2 O2 sensors
TWC = 1 Catalytic converter
I spent a good few hours or so on the forum trying to source a picture of what a Cali vs a Fed emissions sticker looks like. Seems like I may have received bad info in a post regarding the issue.
HO2 = O2 sensor
You got it. TWC = Three-Way Converter, HO2S = Heated Oxygen Sensor
I have a collection of pics of emissions stickers. That's why I wanted to see yours, because I have nothing like that ('99 Cali with one-cat). Yes, that phrase usually appears in all of them. You want to look at the line across the bottom--does it say CAL & OTC or FED & CANADA, plus the Cali's have the verbiage about only for sale in California or other NLEV state or contiguous.
Here is a "99 Cali:
Here is a '99 FED:
Hello I'm new here and not to rehash to much of an old tread but I am running into this problem in California right now trying to register my new to me 99 T4R. It's one cat and everything says 2 but the vin says it was born with only 1?
How did you decide what the VIN says? The VIN does not have a field for that. Parts listings will show both one and two. Only the build sheet will specify for sure, or your emissions sticker. Did a dealer tell you that? Some Cali dude? Please post a pic of your emissions sticker. California will go by the engine family on the sticker and the equipment listed..
