Popping noise from steering
mike_m
When my 2000 4runner (4 wheel drive) is at a stop and I rotate the steering wheel back and forth about 25 degs in each direction I can feel and hear a slight "pop". I know it's coming from the rack/pinion and not the steering column. I've replace the rack pinion bushings, ITR and OTR and just replaced the steering rack guide with new style. I don't see or feel the rack moving up and down when the tires are turning. When I adjusted the steering rack guide, I tightened it as far as it would go to see if the if I could eliminate the popping noise. That didn't cure the issue, so I back off on the adjuster, made sure there was no up and down movement on the rack and left it at that. I also didn't notice any up and down or side ways movement on the pinion. Besides this minor annoyance, the wheel returns to center fine, I have no wheel vibrations when driving or any other issues. Wondering if anyone has anything else I can do/try.
Mike M
I've got the same thing happening with mine (maybe) I get a popping noise mainly when I turn and sometimes just going straight. It's only coming from the driver side though. Anyways, I couldn't figure out what it was, but then I was told my upper ball joint on my driver side is shot and needs to be replaced so I am doing that Monday and hopefully it'll fix it. I know you said it sounds like it's coming from your steering but check your upper ball joints and you might just get lucky!
Thanks for the quick reply, my ball joints are tight. I know it's from the steering cause I jacked up vehicle, went under it and manually turned the pinion shaft and could feel and hear it. I have over 220k on the rack and pinion (no leaks) and will probably just live with it until it dies. I am taking it to an alignment shop this week, so I'll see what they have to say as well.
2001ATL
