Post pics of your drawer/storage system
we swap to toytec hd's when the drawers are in and we're loaded for a long trip. otherwise the wheelers springs are way too soft.
I’ve got OME 889’s (medium) with my drawers… about .75-1” difference (higher) in the rear.
Thanks all!
I ordered Dobinsons Heavy 2" (200lbs constant) for black friday. Just waiting thru all the backlog now. should've ordered sooner.
Done
Does anyone know if carpet will stick to a drawer that was previously sprayed with bed liner type material that comes in the spray can?
I have a drawer that I sprayed with rustoleum bed liner spray and I’m finding it a little annoying when sliding stuff over it because of its grippy texture. If you’ve gone this route, did the carpet adhere okay? And if it did, what type of carpet and adhesive do you recommend? Ideally, I want it black and durable, but not break the bank.
I cut the carpet to fill the bottom of the drawers. Carpet doesn’t move and is easier to remove and clean. I used some extra residential carpet I had.
Built these off of the SolidWoodWorx plans online. After I get some more wood I’ll add in the side cubbies. They have first class customer service and their hardware package was top notch. Now I just need to fill the drawers up!
That looks sweet. I just got the same plans and am wondering after the build if you noticed a different ride with the extra weight in the back? I notice that it's often a topic of discussion but I want to hear from someone with the same set up as I'm planning.
finally finished my drawers
<blockquote class="imgur-embed-pub" lang="en" data-id="a/S01L6x7" ><a href="//imgur.com/a/S01L6x7">drawers</a></blockquote><script async src="//s.imgur.com/min/embed.js" charset="utf-8"></script>
Hey! I like how this sits flush with the second row, do you happen to have the dimension of the inside of the box? Without the drawers? I want to do something similar but want to take a storage bin approach vs drawers and want to make sure the ones I have would fit height wise.
I have probably the most DIY-friendly drawer system that I've seen on the forums, which also won't cost you over a thousand dollars. Originally built for my FJ Cruiser, I migrated it over to my 5th gen 4Runner once the FJ was totaled, and was surprised to find that it is a pretty good fit as well. I used 2 Gilmore-Kramer Bins (Part # 931000), and a wooden platform with a piano hinge to allow it to fold in half for easy install. It is completely reversible/removable in a matter of seconds, so I have the versatility of 2-tiered trunk storage, or a full open-space trunk, depending on what I need. I made a video of the setup HERE, where you can see how it fits in my 4Runner.
erinobr2000
