Power Steering Loss of Pressure
durrell
I'm losing pressure in my power steering and getting a lot of belt squeal when I turn the wheel. Particularly bad when sitting still or driving slow and backing up on pavement. It's also really bad in 4WD, obviously.
Does that sound like a pump going out or a rack issue? It's kind of scary to be turning and all of a sudden lose pressure.
I haven't checked it at all yet. Is there a tensioner for it? If so, where? I know the AC compressor tensioning pulley is loose, because I have to tighten it pretty often to avoid squealing every time the compressor kicks on.
You shouldn't have to keep adjusting your belts, might be time for new ones...I changed mine awhile ago but i can't remember what type of adjustment it needed, once you look at it it becomes obvious what needs to be adjusted.
You need to pull off that a/c belt and check the bearing in the idler pulley. I bet it's toast.
Is there fluid in the ps pump?
3.4L?
I figure the belt is not tight, worn or both.
When you have the belt off, turn the ps pump by hand to confirm it turns without much effort.
Yep, 3.4. I imagine the belts do need to be replaced. They will be replaced when I do the timing belt along with water pump and thermostat, etc.
I changed my inner and outer tie-rod ends and lower ball joints last night. My right inner TRE was trashed and both ball joints were in terrible shape. I never knew my 4Runner could drive so good. It's a huge difference.
Anyway. On the subject of power steering: when moving the rack back and forth to adjust tie-rods and such, the power steering pump sprayed fluid out of the top of the reservoir. I think it had been overfilled. I drove it down the road afterwards and had no problems, but now I feel it would be good to flush the power steering system. Is that something that can be done at home, or does it need to be hooked up to a pump of some sort?
