power window problems
4racerunner
i have a 93 sr5 with power windows and the rear drivers side window doesnt roll down from the drivers seat or on that door and the rear passanger side rolls down fine but back up very slowly and sometimes it needs a little push up to go all the way back up. any suggestions onn what this could be i was thinking the motors need to be replaced...
My truck has the exact same problem. I haven't had time to get into it yet.
But you should remove the interior panels first and take a look for yourself. They are easy to remove. if you need some direction of how just let me know.
When you have it off check all plug connections, blockage (anything in the way of movement), And check the sliders. Your slow moving one could be from a worn slide wheel or crap built up in the track.
If the plugs and connectors are good. the next step would be to, use a test light at the, motor connection plug, and see if your even getting power to it.
im having problems with the door handle itself i took the screw out but its not budging ive pulled the rest of the panel out its just that keeping it on and the switch for the window doesnt move smoothly it will go down and stay there than if you pull it up it will stop in the middle than you can pull it up and than it will stay there ?
the window controls should come off the interior panel. then plug them back in. If you have a test light. pull up on the switch and touch each of the wires with the light and see if any light up. if so its the motor.
The window stopping half way could be a bad ground or the motor getting ready to crap out.
