PParrett's 06 V8 4WD SR5 Build
Couldn't stand the front plate bumps any more...
Modified the lower insert for plate delete.
New Front End
Just now seeing your build thread.
Looks like you work in the car audio world or its a major hobby. None of that stuff you're doing is 'middle of the mall $hit" hahahaha...
Truck looks good, pictures are really nice.
I like the results of the plate delete, but at the same time while i'm reading and looking at pictures i'm like...
That front plate delete is awesome and came out super clean! Every time I look at the front of T4R I notice the bumps and plate mounts and I HATE it.
Just out of curiosity, what are you going to do for a front plate? Legally (as I sadly know) you have to have a front plate on your truck and SDPD has been cracking down on it recently.
Thanks! Electrical and Computer Engineering... but I def fall into the "If it's worth doing, its worth doing right" group of crazy people.
Sprayed and installed the new sport hood! Also went ahead and had the shop respray the fenders that had clear coat failure at the same time. Digging the more aggressive look.
One of the door speakers was blown, so a quick fix with some new Infinity 6x9's.
do the tweeter and mid on the infinty sound right? the tweeter up top has a bass blocker or resistor acting as crossover of sorts on it and without it connected the factory wiring for the bottom speaker doesn't work. i wasnt sure if it sent highs to the bottom speaker with it connected still.
nevermind i see you replaced them with a new set and a crossover. i like your splicing into the factory wiring to keep it clean. i used the wires going to the tweeter and connected them to the crossover then ran speaker wire from there for my component set. mounted my crossover in the same spot.
