Prairie Runner Build
ryananderson05
I live in North Dakota near the prairies so I named this build the Prarie Runner. Let's hope it sticks!
The most recent image as of 9/24/18
Exterior
  • Level 8 MK6 16in wheels
  • Goodyear 265/75/16 Tires
  • Color Matched Grill
Interior
  1. Kenwood DNX69S3 with Apple CarPlay
  2. Kenwood Backup Camera
  3. Update to Homelink console
  4. Update to dual 12V outlets in center console
Lighting
  • Low Beam HIDs
  • PIAA 2800k LEDs in foglights
  • Rigid Ditch Lights on CBI ditch light mounts
Electrical
  • Homemade Auxilary Fuse and Relay Panel
Suspension
  • Bilstein 5100 Shocks
  • OME 884 Coils in Front
  • Toytec Coils in Rear
What it looked like right when I bought it. I was gearing up for a trip to South Dakota.
Interior Upgrades
I read I could put the homelink console and the duel outlet in the center console using the stock wiring harness. Sure enough, they were there and I spent about 15 mins swapping out these parts.
Before
After
Cleaning up the headlights
The 4runner has 196k miles and has spent many days in the sun. The headlights were pretty clouded. I decided to clean them up right away.
Pretty straight forward... I used 1500 up to 3000 grit sandpaper while wet sanding. I then used a polisher and cutting compound. After they were as clear as I could get them I applied a ceramic coating so they hopefully last a few years before I need to clean them again.
They look brand new when finished! I apologize I do not have many good images before!
Headlights Before
Headlights After
South Dakota Trip
So technically I did not own the 4runner for this trip. Previously it was my dads I owned a rusty 3rd gen and he recently upgraded. I did not want to haul my teardrop camper 9 hours to SD so I borrowed his 4runner and decided to buy it while we were there actually.
The 4runner preformed great compared to my 3rd gen! (my 3rd gen was in rough shape). I enjoyed the power and the ride quality.
Anyway, enjoy some images of our trip.
New Brakes
Just got my 4runner back on the road, Stoptech front and rear rotors. New calipers in the front, and new pads all the way around.
I also had to replace the alternator
I got everything from rockauto.com
Bringing camper home
Hey everyone,
Brought my camper home this weekend and grabbed a few pictures of the 4runner hauling it.. also a bonus dog pic.
She saw a cow up close for the first time.
Auxilary Fuse Box
I found a link on Youtube where a guy builds an aux. fuse box and I was actually able to understand what he was saying.
So I tried my hand at building one and below you can see part of my process and the finished product. Not sure If I should find a way to cover the relays or not.
How To Make A Power Relay / Fuse Block | Automotive Wiring
I like yellow, So I bought some yellow lexan, I made a couple of supports and bolted them right to the engine bay.
Figuring where to mount everything on my panel.
From here on out when I add an accessory I should just have to connect the accessory to the yellow wire and hook the switch for the accessory to the white wire. Right Now I only have ditch lights hooked to the aux fuse panel.
I installed another relay between the battery and the fuse box. The power into the relay is hooked to my accessories switch in the OEM fuse panel, this way the accessories only work when the key is on.
Looks very sharp! Nice attention to detail and you're at least level 75 OCD! ;)
Just need to clean that dang battery some!
Ditch Lights
I FINALLY got my ditch lights wired into my auxiliary fuse and relay panel and got a quick picture before going back to work.
Now I need to test the ditch lights and PIAA fog LEDs out in a blizzard.
Also pictured is my new color matched grill I found online for $212, I got two day shipping from Dubai!, I live in ND.
Headlights On
Headlights Off
Was the color matched grille a new piece or used? I'm picking up a pre-facelift 4th Gen and was going to do the Facelift front end upgrade but I like the look of the color matched grille on the 03-05 while the 06-09 grille is chrome normally from what I can tell.
The Limiteds have a color-matched grille. I bought a limited grille off eBay and then modified it. (Not the current grille on mine though)
Ahh, that clears it up! I guess I'll keep my eyes out for a facelift Limited white grille then! I appreciate the info.
Lift
I now have finished my lift since it is warmer. Nothing too drastic and the ride has gotten much better.
Bilstein 5100 shocks
OME 884 Coil in front
Toytec Superflex Coul in the Rear
I also replaced the CV axles at the same time since I had it all apart.
My old 4runner compared to the new one.
That 3rd gen is SEXY!!! DAMN
delislerebecca
