Prestas' CB install + Liftgate mount + 3' firestick (pic heavy)
Presta,
how do you like that Makita Li-ion 18v drill?
I have been thinking of getting one ..
DSC_0155.jpg~original
Makita rocks
I have used Makita cordless for over 10 years and they take a lot of abuse. My first one was the old green version and now I have the one in the picture. It gets used and used and used.
It has a good balance and is not real heavy.
After I wear this one out or drop it enough to finally break it (it gets dropped a lot) I will buy another one.
Presta,
Presta,
Love it man! The wife bought me the set for our anniversary 2 or 3 years ago, drill, impact and light. The impact is prolly the best tool in the bunch, use it a lot more than I ever thought I would. Batteries charge in like 15 min. I highly recommend the set.
Coaxial cable and firestix adapter
I was wondering if anyone could help me figure out what type of adapter I need. I am running the exact same setup, firestik II, coaxial cable with p1-259 adapters and the Comet RS-720 mount.
I guess I didn't read this thread close enough because I soon realized I had no way to connect the coaxial cable to the antenna. I would just go to a truck stop or a place that carries stuff for cb radios however I don't live in an area that they are very common. I was hoping someone could point me in the direction as to the adapter I need to purchase. I found this on amazon but I don't think it will work since the rs-720 adapter has a 5/8" hole and the adapter is for 1/2"?
http://www.amazon.com/gp/product/B0002HRBSU/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Did you end up getting that? I am installing a CB and I'm also stuck on that.
This is possible the most frustrating thing I have ever done.
So I'm assuming the K-4A did not work judging by the picture. Is that the heavy spring or medium?
Edit: Do you think you may have accidentally purchased the RS-720NMO w/ a 3/4" diameter hole rather than the RS-720 w/ a 5/8" hole?
Did anyone find a solution to this? I ordered the rs-720 and it appears that I will be having this same issue when it arrives. Would it be possible to tighten the stud down on washers that are sandwiching the 3/4" hole in the mount? And did anyone ever come to a definite conclusion regarding whether or not the mount needed to be grounded in order to achieve a fair signal?
If you are having issues, give American Radio Supply a try. They were the ones that sorted out my mess of mounts and shipped me one with a 5/8th" diameter.
I tried sandwiching the stud to the 3/4th" with washers and that didn't work for me.
I am pretty sure that the mount has a fair ground because the metal makes contact with the body.
I got the 5/8 hold comet mount and mounted my antenna with a k4a firestik stud and I have had no problems. Theantennafarm guy tried to tell me it wouldn't work and I needed to buy another setup that was 3 times the price
So I'm (hopefully) getting a CB for christmas..... I love the comet mount, but has anyone figured out the issue with the size of the hole?
This is everything I bought and it all works 100%.
http://www.toyota-4runner.org/4th-gen-t4rs/178169-whats-your-favorite-cb.html
I think I'ma go with;
Cobra 29 LX 40-Channel CB Radio
Firestik (FS-3BK) Black 3' 650W Tunable Tip CB Antenna
Heavy Duty Spring
Comet RS-720 Lip Mount - For the rear hatch
Firestik K-4A Stud with Screw-On Coaxial Termination
I plan on putting the unit in my center console, since the unit is so big. Eventually I'll add a PA Speaker..
charlesz
