Pretty good scratches this weekend...
Atticus
So I ended up with a boo boo this weekend. Some pretty good scratches and a little dent. I already tried to use Nu Finish scratch removal. It got some of the tiny ones out, but as you can see there are a lot left... Granted I didn't use a buffer and was just rubbing like normal.
I would rather not have to take it to a body shop, but if I have to what kind of damage am I looking at? I'm also contemplating buying a buffer but I don't wanna eff the paint up more than it is.
Any suggestions??
Thanks in advance.
Can you catch the scratches with your fingernail? If so, they are through the clear and a buffer won't help those particular ones.
If you do want to use a buffer, something like a porter cable 7424 with a medium pad (white) and Meguiars 105 followed by 205 is very gentle. I'd ROUGHLY guess, 50% reduction with that.
That's the combo I use for light correction on toyota paint.
You need to be careful with the paint near the edges though, very thin.
Bet that dent will pop back out no problem (its is on the door right? kinda hard to tell from the angle/lighting) as long as the sheet metal isn't creased too bad. Try pushing it out by hand from the inside.
EDIT: or is it on the lower left just before the trim? You might not be able to get that from the inside.
It's on the lower left before the trim. I can feel the scratches with my fingernail, but it doesn't really catch on them like a deeper scratch would.
Probably through the clearcoat then. You can still reduce the appearance using a mild compound and a random orbital buffer like the combination I suggested above.
Even though you can't remove them entirely, the buffer will round the edges near the scratches and make them less likely to catch light.
When I got my first scratches form tree branches I manually buffed them off with Meguiar's Scratch X. Worked quite well, but involves some work. Judging by the picture Scratch X should work for you, at least it won't make it look worse.
But then I went to another trip and got some more pinstripping, was going to buff them off but another trips was coming.... In other words I don't bother anymore. Maybe I'll try to buff them off before winter.
Well I took it to the body shop and got a quote. Said to fix it would be just over 1000. To get a door skin would be almost 1300. Opinions?
go get another quote from other body shops. If you were claiming insurance 1000 sounds about right.
Find a smaller family run body shop. Not a huge 10+ bay body shop.
That's actually what this one was. Guy works by himself and pulled up his program with me standing there. But I will shop around too of course. Was pretty bummed they wouldn't buff out.
pax at 4
