Hey Folks,
Firstly forgive me if this is the wrong area to post this in and feel free to move it.
I am paring down the fleet and consolidating to a pickup truck that can easily tow the boat and the track car / motorcycles (not at the same time). As such I am going to be selling the 3rd gen (among other fun stuff) and need some help determining what a fair price would be. I don't want to think what I'm into it for, and I don't want to overestimate what it's worth and sit on it forever or underestimate and have someone flip it. Specs are as follows:
2001 SR5, Auto, 190k miles
The good:
Absolutely everything works (power windows, locks, sunroof, rear slide window, even antenna, AWD, 4WD HI and LOW, cruise control etc)
Never had any mechanical issues (knock on wood)
Previous owner did B&H trans cooler to avoid trans contamination issues
Weathertech liners front and back
Tow hitch receiver with 4pin wiring harness that works great
Work done within the last two years since I've had it (have all receipts):
Coolant flush and change
ATF flush and change
Brake fluid flush and change
New gear oil in both diffs and the transfer case
New 2nd catalytic converter and 02 sensor
New OEM cat back exhaust
Almost new (less than 5k on them) Kumho AT51 A/T tires 265/75 16
New battery
New Pioneer headunit with bluetooth music playback and wired with mic for phone calls
The meh:
Timing belt done at 118k (coming up soonish)
Some surface rust on underbody (started life as a NJ car then moved to WNY)
Few scratches and dents on the bodywork (couple on front bumper and one on hatch, see pics)
Couple scratches in the interior (passenger dash and passenger door, see pics)
Brakes work well but there's a grinding noise from the left front when turning left, think it's a backing plate scraping but haven't had a look
Previous owner replaced shocks 3 years ago but they're the cheapo NAPA ones, could probably use an OME kit or new OEM stuff
1 accident on carfax (minor)
The bad:
Rust on the front right middle edge of hood.
Throws CEL for EVAP leak. Quoted over $900 just in parts with no guarantee that it would be fixed. Doesn't affect the truck at all, but in order to pass NYS inspection it needs to be addressed or you need to reset CEL and drive it while keeping it over 3/4 of a tank (doesn't check for EVAP until below) until every monitor other than that sets (allowed to have one monitor not set and pass inspection as long as it's not throwing a code yet). Is currently inspected through October. Wouldn't be an issue for folks that live in a non inspection state (PA etc).
I may be forgetting some stuff and will update if I remember it. Added photos in the post below. Any thoughts on price / suggestions are much appreciated!
Thanks, Tim
The good:
New battery
The meh:
The bad:
Thanks, Tim
