Pro Comp wheels- Toytec Ultimate on the way!
Conspearasea
I finally pulled the trigger and ordered a lift kit for my runner, after reading countless threads and seeing pictures of all types of setups....my head was spinning from all the options.
I wound up going w/ the Toytec coilovers w/ Icon rear shocks (Toytec Ultimate ) as it seemed a few people who had OMEs wished they had gone straight to coilovers...I decided to spend the extra and get the coilovers from the get go. I waited a long time and followed some of the advice of others to do it right the first time. I am sure I made the right decision.
After the lift is installed ( doing it myself when I get off my "hitch" at sea in a couple weeks ) I am heading to the tire store to get tires and wheels.
My mind is pretty made up to get the BFG KOs in 275/70/17, I have owned several sets of KOs and miss having them. As for the size, I spend a lot of time on the highway so I am shying away from the 285s.
I want Pro Comp wheels, and have narrowed it down to a couple of models....all of them state Hubcentric= NO . I see several members running Pro Comp wheels and say they have no issues.
I want to get either the 7189s or the 7105s , but it looks like the 7189s are not available in the right lug pattern anymore? I have seen some members with them, but the pro comp site doesn't list them anymore. I dont like the striped look of the 7289s and am hoping someone may know where to get the proper fit 7189s. I also really like the 7105s, and see that AlexJet has them on his rig.....I am really considering them as a first choice.
Long story short, Question is.....Do I need to do anything special to run the pro comp rims? I am looking at the 17x8, 4.5 inch backspacing w/ zero offset . From my readings, this should bring the wheels out even w/ the wheel flares and avoid rubbing w/ that tire.
Any advice from the pro comp owners, or others with experiences? I am looking to buy the wheels in about 3 weeks and have my dealer giving me the tires for 200 each plus mount etc. Also, my TPMS sensors, can I re calibrate them for the higher psi either at the tire shop or dealer? Or will I be buying new ones?
thanks and sorry for the long winded post, I will be doing a build thread....taking lots of pictures of course ( since other members pics have helped me tremendously!). :surfer:
Where are all the pro comp guys??
Anyone else have some advice on these wheels? The setup I am looking at is going to be
-Toytec Ultimate lift w/ Icon rears- Already ordered and shipped
-275/70/17 BFG ATs- got a price of $202 each
-17x8 wheels w/ 4.5 inch backspace and 0 offset. The website says Hubcentric = No ( is this going to be an issue )
I imagine I may have to do a small amount of trimming or moving inside the wells, based on my readings.
The wheels I am looking at are the 7105 Pro comp
and the 7189 Pro Comp
Thanks for any input, I have read and searched until my head hurts ( I am also studying Celestial Navigation right now which is no help! :nerd: )....Hoping to get some specific advice for my rig.
Anyone know of any other rims similar to these I should be considering? I really like the mostly black look w/ a little silver to go along w/ the SR5s chrome....
No replies yet, but I have another question now.
Can my current TPMS sensors be reset to accommodate the higher PSI the BFGs will be running? Or am I going to need a new set? I have and OBD Scantool code reader....can they be used to reset or change settings ( its not in front of me right now so I cant read the manual ).
Also again for the pro comp guys, especially the 7005s or the 7105s 17". Did you get the 7005-7883s? I am about to order some and want to be sure I get the same as others who have had success with the pro comps.
Hope to get some input this time! :D
Found this online....does this apply to 4th gen Runners?
On many Toyotas, there is a TPMS reset button inside the glove box. To reset the system, turn the ignition ON, then press and hold the reset button for three seconds. When the TPMS warning light blinks three times, the system is reset. Wait at least five seconds before turning the ignition OFF so the system will recognize the new tire pressure readings.
I'm still new here also, so I can't answer any of those questions. I was just wondering if you got all your gear in yet? Did you install it yet if you did? How does it ride? etc...
I am stuck offshore at work until tomorrow night, then I am heading to the Coast guard for a Celestial navigation test friday....It is KILLING me! I am so excited to get this done.
Lift kit is at the house already, wheels delivered tomorrow by UPS and the tires are at the tire shop already! :reddance:
I will being installing the the liftkit myself on Sa****ay, should that all go well, I will be taking the wheels to the tire shop Sunday to get them mounted.
Lift Kit- Toytec Ultimate w/ Icon rear shocks (subbed out for the Bilsteins)
Wheels- ProComp Extreme Cast Black- 7105-7883
Tires-BFG 275/70/17 AT KO
This is all going on the 2007 4wd, should be a nice rig when its done. I will be starting a build thread of my own, and will include pics and tricks as I come up with them. This forum has been a huge help in making my choices along the way.
As far as the TPMS goes you wont have to reset them. As far as I know they just warn you if your pressure gets to low, so you wont have to worry about raising the pressure in the new tires. Congrats on the lift, I am eagerly waiting for mine from Overland Warehouse, but I chose to go 285/70s.
