Pro tips for the AC when it's over 100?
THEDK
2014 TE is fine most the year, but when it gets over 100f the AC isn't capable of making the vehicle comfortable. Being sweaty through an hour long commute is pretty miserable.
After about 30-40 minutes it starts to get tolerable-ish. But it never gets cold.
Obviously parking with the windows cracked, window shades, blowing out the inside air before closing it up to recirc. Filter is nice and clean.
Can't tint the side or front windows sadly.
I put sunshades in the rear windows.
Any other tips? Maybe something for the seat? I found 'zonetech' seat cooler on Amazon and it seems pretty neat.
I have some friends that have used LLumar AIR80 with good results. It is a clear film that helps in rejecting heat.
Window Tint Viewer | LLumar Window Film
Buy a white 4runner. I'm only half kidding. I bought one in white and that was part of the reason.
I'm not sure how much difference it really makes on the inside. I don't have cooling issues though. I think a lot of it has to do with the fact that I live in a very dry climate so 100 degrees isn't as bad as 100 and humid.
I used to think that but not after today..116+, 7% humidity, but truck wasn't to bad inside but don't tell that to my aux battery tendering the fridge...
I read in the news that it was too hot in AZ for airplanes to take off. If a $50 million dollar airplane can't take off - I guess being reasonably comfortable is probably still a win.
have ceramic film put on all your windows. Best mod I have ever done. Reduces heat and IR like crazy! It's not a cheap mod, I paid $700 to do all windows and windshield, but as an example.... today it hit 95 where I am and I don't think my AC was ever above 'LO'
Ceramic film. You'll be hooked and feel like your riding around in a refrigerator you can see what my rig looks like with it done on Instagram [MENTION=115475]TRDPRO[/MENTION]_cement
:iagree:
I had Solar Guard put on the windshield and moon roof. It helped a lot. I used regular tint on the sides, may have been better to use the ceramic type there too.
I don't like the noise, but running the fan on high or second from high speed helps. Our 17 year old Chevy Astrovan still outperforms Toyota A/C. But when the pavement ends, it's 4Runner time.
It was hot today! And anyone who says " it's a dry heat though " obviously hasn't experienced it. /rant
I have a red 4R with softex seats and on my 10 minute drive home it was comfortably cool inside. I have windows and windshield tinted and use a weather tech custom sun shade for the windshield, best $50 spent.
Keep the sun out the best you can. Could be you have an issue with the cooling system too.
No issues with my cooling system at all..I run a constant on fridge in the rig and I believe the compressor was running most of the day.
My rant//you Guys thinking you are going to get 2 or 3 days in one spot off of a battery powering at least a fridge..mmm..not in extreme heat w/out solar or starting the truck a lot and even then challenges...
Have a '14 that I had to learn tricks in Oklahoma heat & sun.
First week I owned the truck, I tinted the front windows ~28% to match the rears. Seriously doubt that's legal in Cali.
If you can't park in the shade, park facing north. This gets equal sun in the side windows over the course of the day, but the rear lip spoiler will block most of the sun from the rear window, and the body of the truck will keep most of the sun off the dashboard. The rear glass is also tinted darker than the windshield, so exposing it to the sun instead of the windshield helps too.
Crack all windows including the rear, tilt the sunroof up but leave the sunshade mostly closed (only about 2-3 inches open). This will let the heat vent better than just cracking windows as the sunroof will act like a chimney.
(If you have it, use remote start for 3-5 minutes)
When you get in the truck, kill re-circulation mode, run fan on step short of full speed (full speed moves air quickly over the evaporator, which doesn't let it cool down). Set temp at coldest AC or one step above (not MAX which keeps recirc on). Running it with a step in the heat direction sounds counter intuitive, but it opens a baffle in the air flow system to draw in air from the heating side, except that since the truck isn't at operating temperature yet, it's not yet heated air and it will allow more outside air (cooler than inside air) to flow into the passenger compartment.
Drop all the windows, drive for about 1/2-1mi (40+mph). Once the AC is blowing cold air, switch the fan directional control to the floor/defrost option leaving windows down. This will help cool down the hot dashboard radiating heat into your passenger compartment and start blowing cooler air at your feet instead of at chest level where it will be going out the window. Once the dashboard cools a bit, close the windows and sunroof changing AC to blow out shoulder vents.
Of course if your AC isn't getting cold then you do have a problem that none of this will help greatly. Might want to consider an AC service where they check the refrigerant pressure differential, you might be low. I know a while back AutoZone/Advanced used to advertise a free check in hopes you'd buy their recharging system, I don't know if that's still the case. Good Luck!
It was 118° on my way home today and AC worked just fine. Albeit, I have window tint all the way around (except windshield). As mentioned before, are you running the AC in recirculate mode?
I painted just the center-top of my old jeep's hard top roof white specifically for heat reduction, worked great. Not sure how that'd play on the 4runner though.. could try white vinyl on roof to start.
It was 114 on the way home today from work. White rig, limo tint everywhere except front windows. 20% there. AC was great. I do park in a parking garage so it wasn't in direct sun but was still 109 in there. Ha ha
If the windows have been up, roll all of them down for a couple minutes while driving to help get out the super heated air. Then I just leave it on max cold and rarely have to turn the fan up past half.
I live in Sacramento as well. I park in the garage so I don't usually have an issue but parked outside during the day it can be hot especially with the softex seats.
I know you said you cant tint the front or side windows, but like others have said they do make clear tint. I put light tint on the sides (with no issues from the law since it looks factory), and UV clear tint on the front. It makes a pretty big difference.
Looking into the clear tint. I got away with some fairly light tint in a Corvette (They have the same compressor as a suburban, even with the clear roof that car would be a meat locker in 105 weather by the time I got out of the parking lot, man I miss that car...)
And yeah, I do recirc - after using outside air at first like Friggin Idiot described.
I think the system is performing to spec. it does a great job at about 96 or under - and reasonably quickly. There's just something about 100+ that kicks it in the nuts.
albertpeter156
