Problem inserting shank into receiver tube
Bimmer-Bob
Just like the title says - is this supposed to be difficult at all? I have a 2" Equal-i-zer shank that isn't sliding into the receiver - should I be using grease or something? It just seems too large - is it? I thought 2" was the proper size.
Use a little grease. If you really want to get crazy, put the hitch in the freezer overnight and it'll shrink just enough to slide right in.
Two-inch is the proper width. Did you measure the mount, and receiver, to see if one or the other is bent?
What I've seen in the industry is the powder coating being too thick. Or the shank is of poor quality. Take a straight edge and check all four sides of the shank. You may notice some "raised" parts. I would grind it down and repaint.
This is all assuming there are no obstructions on the truck side (rust or otherwise) of the hitch.
What is the proper size? I know I've seen threads of people using Equal-i-zer hitches with T4R's, and I don't see that they make a shank smaller than 2"...
2" is the correct size...
Mine fits loose...
Maybe I should lift my truck to compensate...
Your welcome [MENTION=81573]Stifler[/MENTION]
All kidding aside, I'm pretty sure this part is defective. I went to U-Haul today and tried 3 or 4 different 2" shanks, all of which slid right in without issue. The guy working there thought maybe mine had too much paint or something on it, but when he took a look at it he agreed it was just too big. Weird. Guess a trip to the RV store is in order tomorrow.
Check the shape of the corners on your shank. I have a bike rack that didn't fit in the receiver until I rounded the corners with a metal file.
Yeah, it's the corners. I don't have anything that's heavy duty enough to tackle this shank, plus I have movers coming over to pack up my whole house in two days. Gonna drop by the local RV shop (that also happens to be an Equal-i-zer dealer) and see if they can either get the shank to fit, or replace it with a part that does.
Thanks all for your help thus far.
I had the same problem last summer, a neighbour at the cottage needed me to drop his seadoo at a steep and rocky boat ramp. I didn't have my trailer ball mounted and his 2" drawbar refused to fit the receiver on the 4Runner. Had to borrow another drawbar to get it done. I'm guessing there's a manufacturer who's not playing by the rules...
In any case...don't try to drive in a drawbar with a mallet....you'll be cursing when time comes to remove it. Should go in and out easy peasy.
So I decided to take matters into my own hands and pick up an $8 metal file at Home Depot. So far, I've managed to shave down enough of one corner that the shank fits in easily about halfway as far as it needs to, so it's just going to take a little more time and elbow grease shaving down the rest. But at least the issue will be solved.
It's weird because the shank fits in and out very easily into the receiver of a Nissan Frontier that I happen to be driving today. And, like I said before, other 2" shanks fit easily into the 4Runner. So it's not like I can look at one company or the other (Toyota vs. Equal-i-zer) and cry foul. I guess some sort of variance is inevitable.
Our original OEM ball mount fit into the receiver, but the pin woudn't fit through both the receiver and ball mount. Aftermarket ball mount(s) worked and the second OEM ball mount worked. Odd.
AndiGarage
