problem with door
roka
hi
i have a landcruiser 2010
and due to little use the battery doesn't work( battery dead ) and i can't open the door at all ,not with use of the remote key and other ways ( manualy )
how i can fix this problem ?
hi
Since this isn't a LC forum, you're not going to find much help here. I suggest trying one of the LC forums.
Good luck fixing your problem.
hi
Salam.
If you are using the key manually... I'm not even sure how that's possible that it won't open. Wrong key? Call your equivalent to roadside assistance or the dealership you purchased from. Not sure how it is over there, but you may also have roadside assistance given your vehicle is only 3-4 years. Good luck.
hi
Get AAA
Key fob should have a pop out key. Press on the top left or right side and a small key should pop out. I don't have a LC but the last LX I drove had this. GL
I'm guessing the OP got it open thanks to all the replies...
Now it's time for preventative measures. Gotta get yourself one of these, just in case.
