Signal_jp
Im hoping i can get some help from you guys. heres my problem,
I have 17x9 procomp wheels with -6 offset, 285/70 bfg a/t and toytec 3/2 lift. I ordered a set of spidertrax wheel spacers because i want my rig to have a wider, more aggressive stance.
Prior to installing the spidertrax, i was rubbing on the pinch weld, so i bent it and it was good to go. i also did a slight chop of the body mount. now i go to install my spacers and at full turn, the outside of the the tire rubs the pinch weld and the metal wall next to the pinch weld. Iv read i can hammer the pinch weld till its flat? is that safe? can i cut the pinch weld? I also want to know if its safe to hammer in the metal wall inside the fender? any advice would be appreciated. thanks
-james
heres a pic of my rig (dont mind my daughter lol)
-james
