Project White Rhino Iroke's Monster
I am currently IFS now.. Have not made my mind up yet as if I will change to SAS.. I do want to put in a 7MGTE..
What I mean by all the way to the frame is did you have to take the body off for this build? Just curious why you did that? I see you are welding some stuff on the frame.. What is that for?
If you read the other posts you'll see that I'm swaping a diffrnet body on to it and adding a hitch fuel cell and air tank
well since shits broke ill post again i didnt do anything Saturday due to going to a swap meet and a family get together
i did how ever buy some motor mounts!!!!!
Yes I have toyed with the idea but alas time is killer.
I'm just buying them, then I can duplicate them. I have to install the lockers this summer so if you can wait till then I can try.
ok so i got today and tomorrow off so hoping to get a bit accomplished got one of the back corners pretty much finished
before
2013-03-27130754_zpse4288dd6.jpg~original
after
2013-03-27140413_zps7a47e0bf.jpg~original
Also guys need some serious help this ebrake cable is driving me insane trying to get it off i know i can get a new front section from rockauto but not the rear im having major issues trying to get the mid section apart where the threded rod is i can get the back one to spin but the front one i cant get cause the rear spins there is nothing to hold on to i even used vice grips at the vary rear of the rod and it just shreaded the threads im about to cut it
any advice?
well i got the cable apart with a bit of help from some mapp gas lol i dont think im gona put it back on since i will be doing rear disk in the near future and ill put on a drive shaft parking break instead.
Also welded up at least 20 holes in the frame already and i dont think im even 1/4 way done!
also removed the gear box and the shocks now the only thing holding it together is the shackles
also dose anyone know if i can get a new sterring bar from anyware autozone dose not have any
talking about the boomerang sort of bar?
