Projector Retrofit Angel Eye 'Halo' Size
MxwlT4R99
I scoured this forum top to bottom looking for information, I couldn't find it, even when crossing into the dreaded 4th gen section. My question is, if you have a projector retrofit/know of someone who does, what size of halo or angel eye rings are you using? I'm looking into TRS to buy all my stuff and that one part is throwing me off. I want to use the 3" projectors as well.
If you are really happy with your setup, tell me what it is! I may change stuff around.
This forum is boss. I love you all. :target:
I don't know too much about the whole projector retrofit thing although I would like to since I think it's a very valuable upgrade when wanting more lighting. [MENTION=63060]rickashay[/MENTION] may know a thing or two though.
Your halos will depend on which projectors you're using. They have to be sized to fit the shrouds, so TRS should have that info, not 4Runner forums.
Edit: when you order, the order forms will list options, including halos, that are applicable to the projectors selected.
Sorry I'm on the road so this will be brief, sorry.
If you dont get an answer here that is satisfactory I'd suggest you call TRS. Seriously.
As for retrofits go, I made a write up and its pretty decent. You can find it by going to my build and the link is on the first page. You may also find it if you search.
Yeah, I looked at contacting him a few times, and I know he makes retrofitted headlights to sell altogether. I also looked at his build thread thoroughly and found that he's not on here all too often anymore, and didn't want to email him without checking with people who might've had a quick answer for me.
It is a very valuable upgrade from what I call tell, too! My light output sucks a$$, especially when driving in a city environment with lots of ambient lighting, ironically enough.
Now this I did not know. Thank you for the heads up.
Trust me Brian, I know...your build thread is one of the many on here that I am very familiar with. Your truck is really sweet and your projector writeup is awesome! I will be using yours in combination with [MENTION=37079]GottaBeTRD[/MENTION]'s information
and rickashay's projector /build thread to be customizing my ride as the months pass.
As for the tip, I think I'll call them tomorrow and ask, if the order form option that csp mentioned doesn't work quite right.
The halo size will depend on the shroud chosen and where you are wanting to mount the halo. There is way too many configurations for a ton of shrouds. Mounted in front or behind the shroud will vary the size of halo.
Best answer is to call TRS before ordering. GL
I have 2.5 inchs and love them, the only problem i have is that i did'nt put aluminium tape in the rear and the led light up all the reflector. Will try to put pix.
Envoyé depuis mon SGH-T589W avec Tapatalk
