Proper Grease - Driveshaft
gergg
Wow, I have read a gazillion pages on the best/proper grease for the 3rd gen 4runner driveshaft/slipyoke/etc....mine is a 2000...there seems to be all kinds of confusion surrounding the subject, even saw somewhere that the 2000 could use but one type of grease unlike it's predecessors....Anyway, hoping I can get some thoughts that might help me decide what grease to use where, as I would like to get this done tonight.
Red N Tacky, Lucas oil. Works great. Anything like marine grease will work, something that displaces water and dirt. its grease nothing special, you wont mess anything up by buying something like Red N Tacky and using that. I use it on every joint that requires grease on my truck. Works great.
I recently switched to lucas Ex-tra Heavy Duty:
X-TRA Heavy Duty Grease
I have no long term data other than it is a good poly-urea grease. And ANY grease applied often is better than grease applied every 100K miles.
I lube the chassis every 2nd oil change, or right after going offroad - being in a lot of dirt, water or nastyness.
Used mobile 1 red for years - no problems either. Again, the key is to lube her up often :)
It's less about what grease you use and more about if/when it's greased. Especially if you off-road or get the drive train wet consistently.
Go to your local auto parts store and just pick up some. I use moly grease on my driveline and works great. Better than NO grease like how it was when I bought it.
I ask specifically about the use of MP and/or Moly grease on the different zerks. It seems there are conflicting specs regarding this from Toyota docs, just trying to decipher it all. It would seem that grease is grease, but looks like that may not be true.
That's what i thought you were getting at. As you said, pick a brand, pick a type (synthetic or not). Use regularly and all will be well. :cowboy:
I read through all the stuff out there too, until I got tired of trying to figure out which zerk needs what type of grease, on which day of the week. I just got a good, MP grease and I use it all around. Basically, grease each zerk with every oil change, for me.
This is what I got: Royal Purple 01312 NLGI No. 2 High Performance Multi-Purpose Synthetic Ultra Performance Grease
"Wow, I have read a gazillion pages on the best/proper grease for the 3rd gen 4runner driveshaft/slipyoke/etc....mine is a 2000...there seems to be all kinds of confusion surrounding the subject..."
There is no confusion: In my year, for example, the Toyota FSM says use Molybdenum Disulfide grease on the slip yoke, and non-moly on everything else.
However, it has been shown by many, many users over the years(30 years, or so) that any NLGI #2 grease can be used in any of the zerks and there is no long-term difference.
You can follow the book, or do what everyone else is doing.
I use the Moly grease in all the zerks.
I use the mobil 1 red synthetic stuff. Same stuff my dad's been using in his 2nd gen Taco and my mom's 4th gen. No issues for any of the vehicles. Like everyone said, it's more about getting good grease in there rather than the old stuff.
I've been using Valvoline multipurpose grease for about a year with no issues. However, in an attempt to stop the rear slip yoke from clunking again every 4-5 thousand miles, I went and bought some Valvoline Durablend Sythetic blend grease that is supposed to be fortified with moly. I'll give it a try and see if it works better on the slip yoke since they should have moly anyways.
As for the u-joints...I'm not going to worry about the moly making the bearings slide instead roll. If they get flat spots and need to be replaced....so be it. After 379 thousand miles — if they need to be replaced, I'm cool with it.
