Proud new owner of an 85 4Runner
alawson
So 6 weeks ago I flew out to LA and bought this 1985 4Runner. I've read so much on these forums I'm getting myself lost and confused, so I'll definitely have questions as I build this thing. :cheers: I had to include a picture with my crazy dog.
[MENTION=150420]SomeDay[/MENTION] I was going to ask the same thing. Looks super good for it age though!
You have a pretty clean 4Runner!
It looks like rust is minimal (if any) and has the usual wear spots.
Nice!
What is that double lever in the steering wheel left side?
It looks like an aftermarket cruise control switch stalk to me.
:fro:
Nice!
The original owner installed cruise control. I'm not sure how I feel about it to be honest, but I'm assuming it'll be easy to take off if I want.
The original owner sold it to the guy I bought it from in 2016. I think it spent all but 4 years in southern CA, with the others in Washington State. The guy I bought it from had like 10+ old toyotas - FJ40's, FJ45's, lots of cool stuff. This one has 208K miles on it.
The frame is in great condition, no rust I can see, but there is some minor rust in a few places.
Supposedly original paint, but it was buffed down to the primer in some places unfortunately.
Looking really closely at these pics, I can see one problem very clearly - IT'S NOT MINE!
Congrats on a great-looking ride, sir. Makes me miss my 1988 that I drove virtually everywhere for 18 years, 305,000 miles. My nostalgia would prevent me from building, however. But wherever you take her, enjoy!
I'm not really sure.. I want to do a lift with 33s, and I don't want to do any trimming, so I need to figure that out. Down the road I might do 35s, but I'm not ready for that yet. I think I read somewhere there are clearance differences between SAS 1st gens and 84/85 1st gens.. I think 85s need more lift to fit 33s if I remember correctly. I was leaning towards a 3" suspension lift with crossover steering, including whatever else needs updated to accommodate that lift.
I'm going to replace the front/rear bumpers with Low Range Offroad Rock Defense bumpers, or something similar, and rock sliders.
I want to fix up the drivers seat with original fabric, so I'll need to find a used matching seat somewhere. I found one on ebay, but it was pricey.
Then I'll probably put in selectable lockers front and rear.
Honestly I'm not going to take this thing rock crawling much, if at all.. more or less an overland truck that I want to try and keep clean as much as I can, but I want it to be as capable as can be without destroying it.
Sooner than later I'll probably buy a Softopper for it.
going to high steer will be a huge improvement in handling and safety.
SAS'ed 86-95 trucks end up being slightly higher due to the end of the IFS frame having a slightly different bend than the 79-85(84-85 4Runner) factory SA frames. Unless you go with a stock length replacement lift spring your will end up using a new from spring hanger. I would recommend keeping the truck as low as you can. I used the T-G hanger on my 81, it lifted the front way more than I expected. I used the Low Range Off Road low profile front spring hanger when I SAS'ed my 94 and was happy that it came out about an 3/4-1" lower than if I used the T-G front hanger.
The Rock Defense bumpers (low range is owned by T-G) are made by Trail-Gear. Search around on Google, many times you can get a better deal on them with free shipping through Summit Racing or 4Wheel parts.
Selectable lockers is a good way to go...someday for my 94
Thanks for all the info!
Can someone please correct me if I'm wrong on this..
I want to do 33x12.5 - maybe 10.5 if the 12.5 is too problematic with rubbing.
I should be able to fit these with a 3" suspension lift with high steer, right? And if I want to add 35s down the line, would I be ok with this setup if in addition I moved the axle forward? I'd really like to avoid any trimming.
I've read hundreds of posts regarding lifts, etc. but I'm still having trouble figuring everything out. Being a stock SFA, most threads are about SAS'd 86-89 4Rs. Any help is appreciated. :confused:
I have an 84' and I have a 3" lift kit from rough country. I know Procomp also sells a 4" kit. I also have 33x12.5s and it does rub at full lock and full articulation in the front, but im usually never like that so it doesn't really affect the way I drive. If I were to buy tires again I think I would go with something skinnier, better fuel economy and I think they look better, but thats just my .02:typing:
