PSA: How To disable key ignition warning buzzer
IjmRunner
This mod will disable the warning buzzer that occurs when your key is in the ignition and your drivers door is open.
This mod is completely non destructive and fully reversible, no cutting.
What you need:
1. Phillips screwdriver
2. 5 minutes
How to:
1. Remove Key, turn steering wheel 90 degrees left to expose Phillip head screw (Pictured)
2. Remove left screw
3. Turn wheel 90 degrees from center to the right and expose the other screw.
4. Remove right screw
5. Separate upper and lower plastic pieces by gently pulling them apart. To fully remove the lower piece you will need to lower the steering wheel adjustment lever.
6. Under the ignition switch on the right side of the column you will see a white 4 pin plug (pictured). Unplug and tuck away.
7. Reassemble plastic column covers and reinstall the 2 Philips head screws.
NOTES:
1.This switch is called the "UNLOCK WARNING SWITCH ASSEMBLY" digging through the toyota wiring diagrams I have found no other use for this switch other than running the buzzer. I may be wrong, only time will tell. I will run this mod for the foreseeable future and try and discover if any other ECM function was tied into it, although I'm 90% confident, you have been warned. If I find any issues or symptoms, if you decide to do this mod and discover anything, or if you know of anything else this switch is tied in to, please let everyone know by posting below.
2.This mod is only for KEYED vehicles, I haven't been through the wiring diagrams for the keyless ignition 4runners, I don't even know if they beep when the receiver is in the car and the door is open or not.
Honestly the most annoying thing ever.....I might do this. [MENTION=150567]Old Red[/MENTION] do you have any knowledge on this plug from your extensive experience with the wiring diagrams and experimentation?
I drove around with it for 2 days and noticed nothing out of the ordinary, although I have also disabled my seat belt chimes.
I'll see what I can find looking into the keyless 4runners, the keyless version will most likely require a wire being cut as there is probably no physical switch.
It may impact those of us with a remote start module.
Should have zero effect on remote start modules. All this "switch" does is go to ground when your key is inserted sending a ground signal to the ECM that sounds the buzzer. It's not connected to the door switch, nor does it deactivate the 3 beeps when starting the car.
Tanner was one who showed me this simple mod after I asked him if he had found which plug it was !:horn:
For smart key users:
It appears without a techstream (more on that below) you won't be able to stop your buzzer from going off when your key is inside the vehicle.
Your key sends a signal to the Certification ECU (Smart Key ECU) that it is inside the car, which in turn signals the "Combination Meter Assembly"(Gauge Cluster) CPU to sound the buzzer. All communication is done via can bus signal, there is no physical wire or physical switch that can be disabled to circumvent this system, but.................
There are cables that are available online that will allow you to hook up a laptop with certain software to your vehicle to disable it. I'm not going to link you to how to do it, google is your friend, searching toyota techstream could be useful.
I still can't tell you 100% you will be able to disable this, but it's a pretty powerful solution.
-Drew
-Drew
Thank you
2001ATL
