Pulling my hair out (rear wheel bearing or?)
4Rnr4Evr
At this point I have essentially entirely rebuilt the rear end. This last chapter begins after I have replaced passenger side wheel bearing and have installed a rebuilt diff. Still had whirring/humming which I've been chasing for a while now.
Monday I replaced the rear brakes (new everything and now 5th gen reman calipers) since the driver side was messed up. Immediately got brake grinding which was strong on right turn and gone on left turn, so together with the previous diagonal pad wear on this side and the humming/whirring I decided this indicated a bad driver wheel bearing, so I replaced it. When I pulled the axle the bearing was most obviously bad.
To my utter dismay both the brake grind and the humming/whirring noise are still there. The only thing that would make some sense is defective bearing - I got Timken which I thought was the best aftermarket and my other side is a Timken too and it's fine. But the grinding is exactly the same as before and the whirring/humming noise is also exactly the same. I think it's impossible for a worn out old bearing and brand new but defective to sound exactly the same. Plus it felt smooth when I was checking it before the install. Yet I can't think of anything else that could cause the brake grind I got now AND the diagonal brake pad wear I got before. The marks on the new rotor and the previos diagonal pad wear both correspond to inward tilting due to bad wheel bearing.
Is there anything else that could cause the brake rotor to tilt this way? Never mind the whirring noise - at this point I'm willing to forget about it if I knew my entire rear end was good but the brake grind means something is definitely wrong on that side.
My rear emergency brakes got messed up on my reinstall because I didn't use new hardware. This caused a grind, and eventually drag and wheel hop once the brake heated up a ton. Needless to say, the hardware got replaced and I never even use the ebrake anymore.
Are you sure it was the rear? Have you tried the front bearing yet?
Bent axle or axle tube. Both are very weak for the size of the truck.
I would imagine that something like this would produce constant grinding but like I said it goes away on left turn and is strong on right turn. To the best of my knowledge only bad wheel bearings cause this.
Bad pinion bearing does not affect brake wear.
In any case I mentioned I already repalced the diff.
got any pics of the worn pads?
on a solid axle, you don't get much of any deflection with a bad bearing, so that really wont cause excessive pad wear.
Hey, were you able to get a better diagnosis on this? I think I’ve got the same problem. Bought a 2004 v8, noticed a rotational “grind” so checked the brakes. Pads were worn at an angle. Replaced calipers, rotor, pads and 8-10 months later I’ve got the same issue.
It did go away for awhile, but happens more during braking and turning. I have not checked the pinion bearing yet, but like you said, that wouldn’t effect brake wear.
I was convinced I had a bad rear bearing. I replaced it. problem still there. I then jacked up the car on all 4 corners, activated 4wd and diff lock, and put it in drive. to my surprise, it was the front right bearing. sounded like the braked were grinding, but it was a bearing.
Also, If you are missing the little caliper clips, it can make really annoying clatter.
AndiGarage
