Put 275/55/20 Nitto Terra Grapplers on my Limited today
I would like to hear from someone that has run these tires for at least 20K. While there has been lots of smoke from non users, those that have been running the tires for at least a full season.
Thanks,
Chris
Well... it was time for tires before the next inspection (41K+ on orig tires), and I decided to go with the Michelin Defender LTX M/S 2's in 275/55R20 over the Nitto TG's due to very limited off-road use. Note there are different sidewall stiffness options, and I went with the lesser stiffness (no jokes please). I paid about $835 OTD, but have a $70 mail in rebate.
They fit w/o rubbing, but feel noticeably "wobbly" when stressing the sidewall. Of course, we're talking about a 4R, but IMO the stock tires felt more planted than what I have now. Note I had the installer put max pressure (35 PSI). On the up side, they definitely fill out the wheel profile better, and will certainly offer better traction. Also, I didn't see a noticeable change in observed speedometer readings.
Note that the max pressure is 44 PSI. I raised the fronts to 40 and the rears to 42. I hope this will help the feel.
Chris
The limited rims are actually 7.5 wide. There is some confusion on this butnif you search you will find it.
Hi Mindflex,
Sorry but that conclusion is incorrect. We disputed that myth years ago; back-&-forth we went until we finally got to the truth by actually measuring the rim size from inner lip to inner lip... turns out that the rim is 7 inches wide. http://www.toyota-4runner.org/1220771-post45.html My hope was that I would find the stock limited rim to be 7.5 inches wide so I could 'safely' throw on a set of 275/55 R20. The bottom line is that I have been running the 275/55 R20's in spite of the narrow rim and have had no problems with them at all... best tire I've ever purchased and handles like a Top European sports car!
Cheers
[MENTION=133557]Mindflex[/MENTION]
:doh::playball::ybrick::pop2:
[MENTION=83083]rigtec[/MENTION], the person who actually created the post years ago just corrected you!
These pics must be forgeries then
Sent from my SM-N910V using Tapatalk
Those pics prove it's a 7" rim. You can clearly see the measurement from inner lip to inner lip. :doh:
I don't suppose you're also one of those flat earthers as well? lol
Thanks,
Chris
I had the terra grapplers for about 30k miles on a Ford Explorer. No issues with the tires, they still had plenty of tread left when I sold the Explorer.
Thanks for the thoughtful and incorrect response.
See the above link I posted. Also this
Toyota rim size Numbers....Misleading???? - Toyota 4Runner Forum - Largest 4Runner Forum
Rims are 7.5
You are measuring wrong; the measurement is from inside the lip, basically where the tire seals at.
What thread were you reading...
No one corrected me after I posted those photos. I was the one who removed the tire so ALL doubt could be removed! The rim is 7 inches wide! The photo of the firestone fitment catalog was one of the sources from where the misunderstanding was created! If you want to be responsible for resurging that confusion on this forum then go ahead; but just remember: I showed you the actual width using a standard rule with a tape measure so no one would have to guess!
cheers
I'll never understand why there's ALWAYS one in the group that refuses to embrace sound logic and irrefutable proof! I used a standard rule tape measure and he says: "Well that must be a forgery"... A FORGERY????
No one corrected me after I posted the photos. I was the one who removed the tire so ALL doubt could be removed! The rim is 7 inches wide! The photo of the firestone fitment catalog was one of the sources from where the misunderstanding was created! If you want to be responsible for resurging that confusion on this forum then go ahead; but just remember: I showed you the actual width using a standard rule with a tape measure so no one would have to guess!
cheers
[MENTION=83083]rigtec[/MENTION] ... I apologize that what I was attempting to portray with the symbols was taken the wrong way. They were meant for [MENTION=133557]Mindflex[/MENTION]. I know that you were not corrected...I read both of the threads you created back in 2012 in their entirety. I am fully aware that you found information and took the pictures yourself. I meant that you "corrected" the statement that [MENTION=133557]Mindflex[/MENTION] made in post #22 with your post in #23 of this thread, but he still didn't seem to understand that he was trying to refute your statement with a thread of your own creation. I hope we are all now at an understanding, and thanks to you, that the Limited rims are indeed 7" wide.
I now have learned to use the Smilies in a more concrete way (or at least give more of a verbal explanation as to the point I am trying to make)
Too much respect for you to discredit you in that way.
[MENTION=83083]rigtec[/MENTION] ... I apologize that what I was attempting to portray with the symbols at that it was taken the wrong way. They were meant for [MENTION=133557]Mindflex[/MENTION]. I know that you were not corrected...I read both of the threads you created back in 2012 in their entirety. I am fully aware that you found information and took the pictures yourself. I meant that you "corrected" the statement that [MENTION=133557]Mindflex[/MENTION] made in post #22 with your post in #23 of this thread, but he still didn't seem to understand that he was trying to refute your statement with a thread of your own creation. I hope we are all now at an understanding, and thanks to you know for sure, that the Limited rims are indeed 7" wide.
Hi Cymon,
I had a feeling that you weren't disputing my post. The "Like" that you posted on my statement gave me the clue lol! Peace brother!
rig
[MENTION=83083]rigtec[/MENTION] ... I apologize that what I was attempting to portray with the symbols and that it was taken the wrong way. They were meant for [MENTION=133557]Mindflex[/MENTION]. I know that you were not corrected...I read both of the threads you created back in 2012 in their entirety. I am fully aware that you found information and took the pictures yourself. I meant that you "corrected" the statement that [MENTION=133557]Mindflex[/MENTION] made in post #22 with your post in #23 of this thread, but he still didn't seem to understand that he was trying to refute your statement with a thread of your own creation. I hope we are all now at an understanding, and thanks to you, we know for sure, that the Limited rims are indeed 7" wide.
I think its sad that I actually understood what you were saying by those symbols and smilie faces.....my IQ is lower than I thought
Long term thoughts?
I have a 2014 Limited and my Yoko's have 30k on them and are starting to slip on wet roads.
I've been going back and forth between the Michelin Premier LTX (proper size for the 20') and the Nitro G2s (improper size for the 20').
Now that it's been a couple of years, what are the long term thoughts for the Nitro G2s on highway safety (which is mostly of what I drive) and the tread wear?
Thanks in advance.
Hold on. So they are 7.5 ???
I have a 20 nightshade and hate the look of the stock tires. Would love to switch to the bigger tire !
