Qi Wireless Charging (OEM Style)
The little white plastic for the LED light fit just great after a little dremel work.
Note4 charging.
I know I am bringing up an old thread but with the new iphones it got me thinking.
I am going to do this but dont want the dash torn up while I complete everything. Does anyone know the part number for the cubby/pocket plastic piece?
Dang, new iPhones... You got do a hell of a lot of mods for the 4runner with the $1000 for the new phone.
Apple gone crazy with those prices.
I hope you are wrong. I just ordered an unlocked Note 8 from Samsung tonight. I was looking at multi-coil fast chargers to replace the current one.
Note 4 = 144.8mm
Note 8 = 162.5mm
A quick check in the dark looks like the lower cubby is close to 165mm.
The QI is very convenient although I do have a couple 20k mah fast charging power packs now.
Note 4 = 144.8mm
Note 8 = 162.5mm
Note 8 with this case won't fit in either cubby.
https://www.amazon.com/gp/product/B074W6GCZH/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1
E x c e l l e n t ! ! ! ! ! ! ! ! !
Excellent!!! Now my plan to keep the 4Runner longer is getting going... This is high on the mod list...
  • AAEAAQAAAAAAAAgvAAAAJDY4OTI4MmE0LTVlZDgtNGQzYy1iN2U1LWU5Nzk1NjlhNzIwNg.jpg
Pretty bummed my 6plus wouldn't fit in this useless compartment... the iPhone x fits perfect! Just did this mod today minus the optical because the led placement on my charger sucked . Great write up
To remove this pocket is it the two screws and then 4 clips? I removed the screws and pulled a little but ti did not want to come out.
You need to remove the panel that covers the 4wd lever and shifter... Don't forget to unclip the wiring harness for your heated seats if you have them
This is what I was thinking. You open it up and remove the plastic chrome trim ring. Use the inside as a template on the bottom of the tray. Very carefully cut it out. I mean VERY carefully.
Here, I made a sample out of cardboard in a few minutes so it gives you a rough idea. Snap it together with the tray replacing the ring and I imagine it would look factory with the qi logo and a grippy surface. Bonus points for the LED being right there on the surface.
Did you need that 12V to 5V adapter?
Philthyphilthy
